Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
  • Hi Rick
    Have a look in Post #2 here: http://www.vwwatercooled.com/forums/...dex-65460.html
    Keep in mind that some of the newer firmware CDs erase the coding of the RNS510 so you should back that up with VCDS first and then restore the coding after the upgrade.
    POI's need to be stored in the correct folder location (PersonalPOI) at the root (top level) of the SD card.
    Audi A3
    • Originally posted by Ryan_R View Post
      Hi Rick
      I couldnt get that link to open This one does http://www.vwwatercooled.com/forums/...-nz-69790.html Go to the Firmware 412x - Link and click on it
      • Link works ok for me...
        It's the **LOOK HERE FIRST** Important Threads & Stickie Index thread in this subforum
        Audi A3
          Yeah went there and clicked on the 4120 link that says 90.5.5 partitions and it goes to a broken link page.
          Anyway the one I posted has the same thing probably.
          Havent ever lost anything when updating firmware.
          • Ah those links, gotcha. I've had to restore coding when upgrading to one certain firmware. kamold may have since edited the ISO so that it's no longer a problem. Whoever uploaded it must've [re]moved it.
            Audi A3
            • I was never able to get that ISO to work in may car. Must have burnt it to about 10 different types/brands of disc, and never had any luck. I've always been able to burn maps without an issue, so not sure if it is that FW4120 ISO that had issue? If someone has a a disc that they know works in their car, it'd be great if they could send it to me!!
              • Thanks for the info, will do some reading and have a crack over the weekend...wish me luck hope I don't wreck my unit.... will let you know how I go
                • Hi guys, so have had a quick read at the link provided by Ryan. As I don't have a cable is it best to stick with firmware 4020 so I don't have to recode the unit?
                  • Use 4120 I have never recoded it ever and have done incremental upgrades without problems You need to have a C unit or higher for that version
                    • thanks Hillbilly, so I don't screw this right up.. My unit is an original B version.. the part number changed when I upgraded to v3810 to 1t0035680D. will 4120 work with this without recoding?
                      • Originally posted by rickbaron View Post
                        Not sure wait for Kamold to reply He is the Guru on these
                        • No recoding required for any of the firmware images here.
                          • Think he wanted to know which version to use in his B version as it changed from B to D and Im not game to recommend one LOL
                            • Originally posted by Hillbilly View Post
                              Yup that's exactly right. It was an original B ver.. hoping 4120 can go into this unit.
                              • Anyone here successfully ran firmware 5238? Or 5269? For AUS/NZ?
                                Sent from my GT-I9505 using Tapatalk
