Originally posted by robihe
View Post
APR ECU Upgrade MK6 Golf - Customer perspective
They'll not need to remove the ECU these days. It'll be flashable though the OBD port.Originally posted by DracZ View PostDepends if they need to remove the ECU to do the initial flash. If they do, then might take 2 hours? If not, it can be less than 30 mins. Best to ring up the particular dealer and ask them yourself if you need an exact time.
Might be a stupid question but if a engine problem does occur, how can they link the ECU reflash as the problem?Originally posted by coreying View PostHi, I'll try to answer all your questions.
1) Does the APR ECU stage one tune for a 118TSI breach VW factory warranty?
Putting any aftermarket component in your car (ECU, stereo, wheels etc etc) does not breach the VW factory warranty. However, if the aftermarket component caused a fault, that may not be covered. So in other words, if you flash your ECU and your windows fall out - VW will fix y our windows under warranty.118TSI|United Grey|Manual|Sports Package|Bluetooth|Chrome Scuff Plates|Side Tints
Hmm, from what I know there seems to be a new 'lock' of some sort placed on the newer '10 models. Not too sure about the other tuners, but APR has spoken up about the topic even tho it does not explicitly state so on their website.Originally posted by h100vw View PostThey'll not need to remove the ECU these days. It'll be flashable though the OBD port.
"The MK6's in the US have new communication protocols that require removal of the ECU to be flashed." LINK (dated 11/03/10)
A REVO rep clarifies / confirms this later on by saying that the ECU also needs to be *opened* and not just removed, for the initial flash.
Not sure if this applies to local models however. Anyone with a '10 MK6 have any solid info?
The latest GTI MK6 won't be able to upload through the OBD port (ie built 2010) and need a special tool, but best to check with the installer. 09 built cars may be ok.Originally posted by h100vw View PostThey'll not need to remove the ECU these days. It'll be flashable though the OBD port.
It'd completely depend on what the engine problem was! I'm not a mechanic, so I can't really get more specific.Originally posted by waterboy View PostMight be a stupid question but if a engine problem does occur, how can they link the ECU reflash as the problem?
But I could say that the only 118TSI engine problems reported on this forum, happen on the stock ECU. Although it could still happen on an aftermarket ECU, VW aren't going to blame it on that when you can turn around and present many cases of it happening on the stock ECU.
Have you chipped that new GTI yet, Greg ? Time to get some real power under you, its not like that wimpy R32 you let go ....Originally posted by G-rig View PostThe latest GTI MK6 won't be able to upload through the OBD port (ie built 2010) and need a special tool, but best to check with the installer. 09 built cars may be ok.
would people post on this forum that there car is chipped & they have an engine/gearbox failure?
there is people on this forum that work for volkswagen. correct me if im wrong2004 GTI, GIAC, DOWNPIPE
2007 R32 3DR MANUAL
2010 NAVARA D40
2016 Q7 4M 200kw
You will find that so called 'clonking sound' (bit of an over the top description in itself) is simply because the engine is Direct injection.... I myself agree it's not the most comforting sound but you will HAVE to get used to it... It's not the engine being damaged it's simply because these types of injector are much louder than port injection. Most noticable when LABOURING as well as when on idle an starting.
Stoney!6 Sp Manual 118 TSi
Colour: United Grey
Build Date: August 09 Delivery Date: 16th Oct 09
ODO at last fill: 2555km
Avg Fuel Cons at last fill: 8.6
The way to fix that would be to get an RSC exhaust and listen to that insteadOriginally posted by Stoney! View PostYou will find that so called 'clonking sound' (bit of an over the top description in itself) is simply because the engine is Direct injection.... I myself agree it's not the most comforting sound but you will HAVE to get used to it... It's not the engine being damaged it's simply because these types of injector are much louder than port injection. Most noticable when LABOURING as well as when on idle an starting.
Stoney!
, or turn the music up. Good to know the 'rattle' isn't anything to worry about.
and here's a nice video of that RSC exhaust..Originally posted by G-rig View PostThe way to fix that would be to get an RSC exhaust and listen to that instead
YouTube - APR VW GTI MK6 GTI 2.0 TSI 3" RSC Exhaust Compared to StockGolf Mk6 GTI | Deep Black Pearl | 6MT | 5dr | 18" Detroits |
Mods Ordered: RTR ECU Remap | 3" Milltek TBE | VW Racing Intake | Revo Intake Pipe |
Accessories: Gloss Black rear VW badge | OSIR Foot Rest | P3 Gauge | GTI Scuff Plates | Yellow LAMIN-X fog light tint | PIAA Yellow Fog Light Globes |
Apologies if this had been stated previously ...
How much is the APR Stage 1 and what will the power and torque figures be for a 118TSI ?
Thanks guys.118TSI, DSG, Candy White, Sunroof, RCD510, Dynaudio, USB + iPod cable, Reversing Camera, Adaptive Chassis Control, Prem. Bluetooth, Fogs, Tint and Mats.
