This is probably a bit long and waffling, but I expect it may be of use to anyone else thinking of remapping a 118TSi with 7 speed DSG.
I have a 2 week old 118TSi + DGG. Last week I bought the APR Stage 1 remap.
The only reason I did not get it done straight up, was I wanted more time to:
-research the product
-ensure my new car had not post delivery warranty faults, and
-to get to know my car in Stock form so I could appreciate the changes.
Getting it burnt was quick and straight forward taking about 30 min. I had it done by my local APR Rep, Dean at Volkspower in Melbourne. (His operation is impressive and is the antithesis of my local VW service centres where I could not get within 100' of a mechanic or engineer let alone talk to one.) Initially I was going to get the APR Free Trial done, however after hearings Deans entusiasm for the product I just cut to the chase and got the full monty straight up.
Finishes up with a burn report email from APR detailing install success, date, ECU & APR program serial numbers. Personally I feel APR could do a little better in this regard. Something more substantial than an email and a receipt to acknowledge the vehicle has the tune. A certificate stating what was loaded and the expected gains would be a nice touch to certify the modifications. But this is only a minor criticism. And perhap a bumper sticker or two
How does it go? The torque increase is so very noticeable... Some examples:
On the highway at 110km, "D" with Crz control in 7th gear, come to a reasonable sized long hill, and I wonder how many gears the DSG will downchange on the way up. Will it drop back to 5th or 4th even? Nope it holds the speed (to the km) and stays in 7th the whole way. Impressive.
Again - Chuggin around town in "D", 7th gear at 60kph and about 1300rpm. Come to a hill, lightly press the accelerator, supercharger rumble becomes more noticeable and the car holds the the speed AND the gear. Again Wow!
In this situation if I revert to stock mode it will change down to 6th far more readily.
Interstingly - at this 1300rpm I am off the bottom end of the APR "Stock vs Stage 1" Dyno chart which begins at 1750rpm. This chart shows "Stock" has more TQ and HP than "Stage 1" at 1750 revs??? This does not make a lot of sense to me. One would have thought it useful for the remap chart to show gains at the rev band drivers will be in during the everyday commute at 60 kays. I can only think this is a limitation of the Dyno or the way it is charted because the gains are there at very low revs too.
There is a decent hill just near my house and I can Switch between "Stock" and "Stage 1", drive up it and the difference is marked. If I accelerate quickly to 60km in "D" and drive up in "Stock" the car will only get to and stay in 6th at ~ 1800rpm. If I do it in "Stage 1" it will quickly get to 7th gear and happily stay there at 1300rpm. I can repeat this test and keep seeing the same result. As the remap does not do anything to the DSG change points it can only be increased torque that is causing the different change points and the ability to climb the hill in the higher gear at lower revs.
When I plant it from standstill the acceleration is so smooth and noticably quicker.
The car no longer has the occasional pregnant pause when launching from standstill in a hurry. For example when wanting to zip from standstill into a gap in moving traffic. On a couple of occasions with "Stock" I had got that horrible sinking feeling when I pressed the accelerator to get going and little or nothing happened. Instinctively Pressed more and the car launched with a squeal of tyres. Doesn't do this anymore with the APR Tune. Just gets going smoothly and smartly now with no pause. Interstingly my installer stated that this benefit alone is arguably justification for the remap. I tend to agree.
I realise that without empirical data it is hard to quantify any of my above claims. It does however put a big smile on my dial when I drive it....
As others have mentioned about the APR product, Switching modes is straighforward. Just make sure it is switchable post burn, as I found out, it is possibible to inadvertently install the product without the switching functionailty being active.
So I am very happy with it and would recommend it. Shall report back once I have more hours behind the wheel. Will try to answer any questions you guys may have of an end user with regard to this remap on a new MK6.
Cheers,
Logger
Cheers,
Logger
