look pretty similiar to the forge one
Front mount options?
Remember i import the Cupra bushes, get me a part number and ill do some pricing up, it might just work out.
JmacAlba European
Hey jmac!Originally posted by Jmac View PostRemember i import the Cupra bushes, get me a part number and ill do some pricing up, it might just work out.
Jmac
well really would like the pd160 intake set up!
but i found that link as a alternative, worried it wont fit ha
can any1 think why my boost seems low, seems to be hitting 5 pund=(GIAC | FORGE | D2 | TURBOSMART | K&N | XFORCE |
How are you measuring the boost?
i was just going straight of the boost gauge, none of the lines are obstructed or anything, just soemthing doesnt seem right, i remember when it used to feel like it was torque steeringOriginally posted by h100vw View PostHow are you measuring the boost?GIAC | FORGE | D2 | TURBOSMART | K&N | XFORCE |
Got to love boosting on a cold winters night!Originally posted by Blitzen View PostIs your car tuned?? If not, stock boost is about 6 or 7 PSI. Tuned, I have seen mine holding 21 PSI in 5th with an outside air temp of -2 degrees C.MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
You need to check the boost while pulling up a hill really. In 3rd or 4th if you can. Start about 2000 revs and run it up close to the red line.Originally posted by FLYINGTI View Posti was just going straight of the boost gauge, none of the lines are obstructed or anything, just soemthing doesnt seem right, i remember when it used to feel like it was torque steering
In 1st and 2nd the engine will gobble up boost, as fast as the turbo makes it. In 3rd the turbo gets a chance to get ahead of the engine. Especially on a hill to slow down the acceleration.
Looking with VCDS is better still, your boost gauge may not be very well calibrated.
ChipTuning is a proven product that is backed by great customer service and reputation, along with APR, GIAC, REVO, and Custom Code... Or you could jump on eBay and likely get something that is unproven, or worse, do damage to your engine... At the very least, look here in Australia for a tune before you risk things on eBay.Originally posted by FLYINGTI View PostChiptunning product??
are these just replacement programs??
i know theres stuff on ebay, but could u trust any of them??
Even though there are alot of VAG cars that use 1.8 Turbo engines, there are a lot of different engine codes, power outputs, and internals associated with the engine between the cars, so if you see 'will suit 1.8T', don't automatically assume that that particular part will automatically fit or suit the Polo GTI...
Hey gav!Originally posted by h100vw View PostYou need to check the boost while pulling up a hill really. In 3rd or 4th if you can. Start about 2000 revs and run it up close to the red line.
had a Quick squizz at the motor thismorning cause still running crappy, i followed on the the hoses up the diverter and there was a clamp all the way at the bottom that must have been from the old diverter but then u know the lil 5mm hose that come off! that looked like it had a sharp corner on it, fixed them up, then ...... I HAVE BOOOSTTT LOLGIAC | FORGE | D2 | TURBOSMART | K&N | XFORCE |
