got a full milltek exhaust, 2.5" all the way, more than enough, you need more if you go +300Hp.
after a remap you notice you can get more Hp from it.
all upgrades don't make that much diffrence on stock engine, once mapped it's another story.
things that are restrictive on a Polo GTI:
intake pipe: don't make much diffrence but it will be better (use a seat one if you still have stock airbox)
Downpipe & CAT: every catalysator is restrictive (get a sportcat or none at all)
Turbo intake pipe: stock one has a 90° turn where it's going to the turbo, at this turn it's reduced in size (get a Forge one)
Throtlle body pipe: on LHD cars VW installed a "sound pipe", pretty much useless wich mess up the flow. (Forge needed)
Intercooler: stock one is to small and sits in a bad place, pretty much anything is better (i prefer seat sport with Forge piping)
software: get it mapped because stock a polo makes only 0.6bar at his best
(best = custom tune)
fuell pressure regulator: when you do all the above and get it mapped you will need a 4bar one, stock one can't give enough (TT225 & Cupra R)
if you want i can post pictures of all the restrictive things, when i changed them i took those pictures.
odd to see the stock Turbo TIP next to one from Forge, or dowpipe next to milltek one, clearly see diffrence in size in all the things.
(best = custom tune)fuell pressure regulator: when you do all the above and get it mapped you will need a 4bar one, stock one can't give enough (TT225 & Cupra R)
I must admit after reading all your real world info is mighty tempting mate! Keep it coming.
