Originally posted by POW
View Post
Polo GTI High Oil Usage - Discussion Thread
This is a sticky topic.
I did top up once 750ml after 2750km. Not sure its reflect the real daily driving though. Because the first 2000km almost no change on the dip stick. Only drop after i went for a freeway trip. I m keep an eye on it after top up.2013 POLO GTI Black
2005 MKV 2.0 FSI Black
Originally posted by POW View PostI did top up once 750ml after 2750km. Not sure its reflect the real daily driving though. Because the first 2000km almost no change on the dip stick. Only drop after i went for a freeway trip. I m keep an eye on it after top up.
Originally posted by k0e1 View PostHi everyone after an engine replacement engine I'm still getting about 2000km before my oil light turns on. So I went back to the dealership asking about the new oil squiters. He told me that my 2012 polo GTI has the CAV engine and can not have the new oil squitter fix as it already contains that part in the first place, that the oil squitter fix is only for the CTH engine. Any truth in this?Last edited by mongo; 06-01-2015, 10:09 PM.
my car is MY13.5 gti with CTH engine, owned it since new, 21k kms on the clock at moment.
It consumes as much as 500ml every 1000kms when my wife drives it at "D" mode and black soot came out all around the hatch in days.
However it consumes less than 500ml every 5000kms when I drive it with manual shift only and I can barely the the black soot after 2 weeks before I took it to a wash.
Very very strange behavior of this little car.
As I am driving this car at most of time therefore I never took it to the dealership for oil test. Regular check ups and oil top up by myself is sufficient. Maybe I am just lucky.
After doing oil squirters on over 5 cars now, never had one return with oil consumption issues. So I would think that VW have found the solution..Volks Handy
Originally posted by Snail Style View PostAfter doing oil squirters on over 5 cars now, never had one return with oil consumption issues. So I would think that VW have found the solution..
This sounds like a promising development. Can anyone think of any possible problems that these modified oil squirters might cause? Sometimes these sorts of fixes cure the original issue, but cause other ones.Now gone.... 2012 Skoda Fabia RS
Originally posted by danield View PostMy dealer hadn't heard of the fix for my Fabia RS but after a little research they have agreed to change the squirters. Going to see them this week to book it in. Engine is the CAV by the way.
So...
The technical bulletin/product information the dealer should be referring to is 2025520 which is currently in it's 9th revision to date(2025520/9).
>CAV 438345 - optimised hose for crankcase ventilation, 03c 103 474 ad;
>CTH 023901 - optimised air intake, 6r0 129 684 e;
>CTH 165646 - oil injectors with 1.2mm diameter, 03c 103 157 a;
Replace oil & filter;
Update engine control module software, latest revision being 03c 906 027 AR with 9970 version.
So basically if your getting around with a CAVE123456 equipped vehicle, you would need all three improved parts, etc.Volks Handy
Thanks for the awesome information. I shall speak to my dealership and see what they say so althought the oil injectors has a CTH part number to it. It will still fit in a CAVE engine?
