Polo GTI High Oil Usage - Discussion Thread
This is a sticky topic.
  • Originally posted by Snail Style View Post
    Requires sump off only, the oils squirters/injectors sit under the pistons in the cylinder bore. Cylinder one is the only tricky one to get out. Allow about 4h for the job however most will want the car overnight to do it properly, so they can let the sealant dry correctly and recheck for leaks.
    I'll have to reread the bulletin but im 90% sure all the repairs are done at once, shouldn't be doing the breathers(easy) and then injectors after(involves work). This is kinda showing that the dealers are abit half-arsed.
    Snail Style, you've said that the new squirters have bigger bores. In my mind, they should be squirting out more oil, leading to higher consumption... Unless more oil keeps the pistons cooler, leading to less burn off?
    Or is there another factor(s) involved? Care to speculate?
    Sent from my Nexus 7 using Tapatalk
    2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
    Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
    1st Ride: 1988 Red VW Fox Sedan!
    • That's right more oil = cooler piston and lubricated bore. It's not spraying into the chamber itself but underneath.
      Ok so i also double checked. Bulletin is 2025520 and all work(breathers, ecu update and injectors) are all done at the same time. Only time injectors aren't req is for late model CTH engines, however the bulletin doesn't apply for those vehicles.
      So as i thought, dealers are being half-assed in alot of cases.
      Volks Handy
      • Well then, that settles it, I think. I should get this done. Time to make an appointment with the dealer and see if they will provide the fix out of warranty...
        Won't be easy because they claimed that my car had already been fixed. I asked them to document that I was incredulous, but don't think they bothered. Will see how much goodwill is on offer!
        Thanks Snail Style.
        • Originally posted by brad View Post
          Stump, I read your post & my thoughts are: "Doesn't he ever check his fluid levels?"
          Yeah, that's a fair call Brad.
          Truth is, it's probably laziness with a good dose of complacency and ignorance. The older I get, the less I want to do....
          Ignorance would be 90% of it.....Hey, I purchased a new car, no more worries. You get what I mean.
          In my defense (not really ) since both issues, I do get under the hood more frequently.
          The water has only ever dropped about a cm and the oil has barely moved a couple of mm's.
          Greg
          2015 Golf R
          • Originally posted by RoknRob View Post
            Thanks Snail Style.
            If the oil consumption is falling into the specified limits, a tiny 500ml/1000km(LOL), then they will not offer any goodwill/repairs. However if you somehow failed the test then they would have to fix it technically as a repeat repair.
            Volks Handy
            • My oil consumption tests have always been borderline. On one occasion they were particularly meticulous, and found that my car used over 600 ml per 1000km. They have performed all of the supposed fixes so far.
              The one catch is that at the last oil consumption test they told me they found the car used only 100 ml which was clearly not true. That was just before the warranty ran out.
              Anyway, can't hurt to ask!
              • Aslong as there is a history of the issue recorded, then VW will come to the party and cover costs. Otherwise you will be able to hit them through ACCC.
                Volks Handy
                • 2000km after the piston jet replaced.oil at top of B on dip stick. Happy with that
                  2013 POLO GTI Black
                  2005 MKV 2.0 FSI Black
                  • That's not bad but I guess it could still be better. I would assume all engine have a degree of oil consumption (even mine looses oil ~500ml in a 15,000 service period - 1.2tsi) it looses more in colder weather, so letting it warm up first is a must.
                    • Compare to 1L every 1000km,i cant complain now. May be need 2 top up between service now
                      2013 POLO GTI Black
                      • I was sitting at around 220ml per 1000km before the first service. I'm 4000km past that now and it's dropped to 120ml per 1000km.
                        • 2000ks done since oil squirters done.
                          Oil level has not moved on dip stick.
                          Exhaust tips staying cleaner for a lot longer.
                          Car is now how it should have been 2 years ago.
                          • Hi All ,
                            I have Polo GTI 2013 with CTH engine. (26000 km ) Oil usage was 1lt for each 3000km when I was using castrol 5-30. Then I changed oil with mobil 1 ESP 5-30 and oil consumption increased to 1lt for 2000 km . Last oil warning come up at 1600 km and I decided to visit VW for that. I will do that this week but this is first time I heard about oil jet upgrade. To be honest even did not know about such a part of engine. So is there anyone at this forum with oil jet upgrade but still have oil problem ? I am writing from Turkey and I am not sure that VW Turkey is aware of that or not .
                            Regards
                            • Is it still under warranty?
                              Go to the dealer and follow their process, in Australia we have to do a consumption test, (over 500ml per 1000kms) then breather mod, then another C Test, then oil squirters.
                              No person appears to have oil consumption after the Oil Squirters have been done.
                              Owner and Operator of 2013 Polo GTI - Sunroof - Xenons - Reflex Silver
                              APR Stage 2 Tune - HP Carbon Airbox - Jetex Stainless Cat Back Exhaust - APR I/C
                              Plus a few other bits and pieces.
                              • Breathers are supposed to be fitted at the same time as the oil injectors....
                                Volks Handy
