VCDS Tweaks
  • Hey folks, I've just recently got a 2016 140TDi Highline w/ Lux pack and I'd like to do the sunroof close tweak and get traffic working..
    I recently bought a VCDS cable from Total Car Diagnostics... turns out it's a 12.12 version cable/software..
    It seems to work and report everything ok on my MY13.5 Touareg, but when connected to the Passat, I get .ROD file errors.
    According to the TCD emails delivered after ordering it, it claims it only works with version 12-12.
    I tried to download VCDS 18 off Ross-Tech site, but it won't find the interface..
    Am I kinda stuffed here?
    MY16 Passat 140TDi Highline - Indium Grey - Luxury Pack
    MY13.5 Touareg V6 TDi 180 - Silver
    • Originally posted by chopsticle View Post
      Hi mate,
      I've had a look at the website for the product you bought and yep, you're pretty stuffed. They're even open that they're selling fake cables and that it's limited to only their cracked 12.12 version.
      VAG-COM VCDS 2018 - OBD2 Diagnostic Cable & Software (for VAG Cars: VW, AUDI, SEAT, SKODA)
      I'm totally blown away they're selling fakes. Just wow.
      Edit: I've reached out to the team at Ross-Tech to let them know TCD are selling these ****ty fakes.
      • Originally posted by mythik View Post
        Hi mate,
        Hmm ok, thought it might be too good to be true. Anyone in Melb inner west/port Melb that has the right gear and can hook me up? I read up on the whole sunroof close being disabled in Aus. Boo hiss!
          What's needed is:
          Sunroof Comfort Closing/Opening:
          1. STG 09 (electrical wiring)
          2. STG Access Permission -> Function 16
          3. Enter access code 31347
          4. STG Adjustment -> Function 10
          5. Channel (10) access control Select 2-SAD Comfort close
          6. Set value to active
          7. Channel (11) access control 2-SAD Comfort open
          8. Set value to active
          Enable Traffic Information (TMC)
          Step 1. On "Select Control Module" option click "Select"
          Step 2. Select "5F-information Elect"
          Step 3. Select "Adaptation"
          Step 4. Using pull-down menu, select "Fee Based Traffic Information (TMC)" channel (it's about 20% down the channel list)
          Step 5. Enter "1024" into "New Value" box and click "Do It!" tab.
          Step 6. Click the "Yes" tab in the "Re-code Invalid" screen if it pops up. (mine didn't).
          Step 7. When the screen in Step 5 returns, click "Add to log" to record a copy of the change report.
          Step 8. Click "Go Back" (in Step 5 screen) and exit the VCDS software
          See if you can do any of the above with your current cable first.
          I can help you if it doesn't work out. I'm in the eastern suburbs. PM me. My fee is a 6 pack of nice beer for simple coding.
            What's needed is:
            I tried sunroof coding but when I went in to stg09, I got an error in vcds about a missing .rod file. I was able to enter the security code but can’t access 10-adaptation as it’s greyed out.
            I tried copying the newer rod files from
            V18 vcds which I downloaded from rosstech, but it didn’t seem to work. 10 is always greyed out in multiple menus.
            Didn’t have this issue on my other car though so much just be an age/compatibility thing..
            I’m immobile for the next few weeks thanks to foot surgery so no rush I guess. A 6er is easily done
              It would also be worth trying a simple email to the company you bought it off about a newer version of their cracked software. See what they say. I see on their site they have a 17 version.
              • Managed to get hold of a 17.8 cable and was able to do this. Sunroof now opens and closes and got traffic to work. Now to review several pages and work out other cool ****.
                I don’t have the active dash unfortunately but plenty of other tweaks look sweet.
                I saw that you can get the rear indicators to alternate between the outside and inside lights, is it at all possible to do a sweep like the newer Audi’s?
                  Our indicators are only on the outside half of the rear lamp unit so any sweep would be pretty short without a hardware change as well unfortunately.
                  • Originally posted by pyridinite View Post
                    Fair point, I took a squiz last night and you're right, only the outside wouldn't probably work...
                    I'm interested in the legality of mucking around with the tail LEDs in unison with blinking the indicator?
                    I got the outer-LED to blink in unison, just wonder if that's "legal" or if no one really cares about that stuff?
                    Oh and another thing..
                    I tried to enable the Traffic Sign Recognition and Needle Sweep using the instructions provided earlier in this thread, and while my coding was accepted, it didn't seem to save.
                    Same with the Needle Sweep.. I have a MY16 with older style dash, not the active one.. does this matter?
                    Re Traffic Sign - does my car not have the required hardware to use this function?
                    I've only had the B8 about 4 weeks and still new to all this stuff.
                    • hi. I got an alarm horn installed at my passat b8 which is delivered at november 2017. I am using vcds version 18.2, but I can not reach "Address 09: Central electrical system" to code the part. Is there any workaround for this ?
                      Subsystem 5 - Part Number SW: 5Q0 951 605 A HW: 5Q0 951 605 A
                      Component: Siren, DWA 005 0314
                      • Originally posted by Dark975 View Post
                        [ATTACH=CONFIG]33339[/ATTACH]
                        These BCMs do not have any coding.
                        All changes are controlled through adaptation channels.
                        • Originally posted by kamold View Post
                          Thanks kamold. I checked the adaptation channels and found the correct one.
                          • Hi there, had not much idea about this vcds thing. Do i just buy all the gear from ross-tech and will it work with all my cars in my sig? sorry for noob questions. cheers
                            2015 Carnival Yellow Honda S660​
                            2023 MY23 Nevada White Cupra Formentor VZx
                            2024 MY23.5 Moon White Skoda Scala 110TSI Signature
                            • Good luck getting noob answers. I've been trying for a while.
                              • VCDS Tweaks
                                Just check on the Ross tech site. They specify all the vehicles that are compatible with each cable.
                                Some of the cables aren’t compatible with the older cars - especially if you’re buying a second hand cable pays to check.
                                - Tigger73's 125TSI Build
