Hi. I want to disable the DRL when flashing high beams to have a Stroboscope effect. I saw videos of it online but never found the coding for Passat B8. I only found how to enable fog lights when flashing. Any help on that will be much appreciated. Thanks.
VCDS Tweaks
 Hi Guys,
 I followed the steps below from another page on here. I now have the 10 colours and they work on the dash. The only only thing i cant get to work is the LEDs in the doors. My question is, do the doors change colours in the Passat MY16 or are they white only. Is there a way of checking? I have changed the dials and the colours are there. I just cant figure the door leds out.
 Steps:
 Control unit: 5F Information Control Unit
 Adaptations:
 Car_Function_Adaptations_Gen2: menu_display_ambient_illumination: activated
 Car_Function_Adaptations_Gen2: menu_display_ambient_illumination_over_threshold_h igh: activated
 To get the cool dials in the AID
 Control unit: 17 Dash Board
 Adaptations:
 Display depiction: Version 3
 Tube_version: variant_4
 Control unit: 09 Central Electrics
 Adaptations:
 Ambientelicht Farbliste: Rotwert Farbe 1: 144
 Ambientelicht Farbliste: Gruenwert Farbe 1: 24
 Ambientelicht Farbliste: Blauwert Farbe 1: 28
 Change all colours up to 10, none can be R: 0, G: 0, B: 0 as none will work
 I got the numbers for RGB from MS Excel (format cell > fill), but from other posts, Create Color Schemes, Test Color Combinations - Colorspire will give the same result.
 Pick what colours you like, find the RGB, enter those numbers into Rewert (Red), Gruenwert (Green) and Blauwert (you guessed it, Blue)
 My favourite colour is Maroon, so R, G, B is 144, 24, 28, but need to lighten the colour up a bit.
 I also have the below settings active, again, not sure if they need to be or not, but they work.
 Adaptations:
 Int. light, 2nd generation: weicher Farbwechsel: active
 Int. light, 2nd generation: Instrumententafelbeleuchtung mehrfarbig: active
 Int. light, 2nd generation: Mittelkonsolenbeleuchtung mehrfarbig: active
 Interior light, light configuration: Ambiente_Applikationsleisten_in_Instrumententafel: installed
 Interior light, light configuration: Mittelkonsolenbeleuchtung: installed
 Interior light, light configuration: LIN-Dachkonsole lokal aktivierbar: active
 Interior light, light configuration: Ambientemenue mit globalem aus: active
 Interior light, light configuration: Ambientemenue mit alle Zonen: active
 Interior light, light configuration: Ambient_Farbliste_HMI: active
 Interior light, light configuration: Frei_Farbwahl_ueber_HMI: active
 Cold Boot MIB Unit
 Hold down left button for 10 seconds (or so)
 Wait for restart
 Reset Background Lighting Setting in MIB
 with MIB on, goto the below;
 Menu > Vehicle > Settings > Factory Reset > Background Lighting > Reset
 Then you can go into Menu > Vehicle > Settings > Background Lighting
 You should have 10 colours at the bottom to choose from, select a colour, and both the MIB and AID change to that colour. If not, there may be a 3 colour small box to the right at the bottom. This doesn't change the Interior Door Lights, as on mine, they are just white.
 I've seen a couple of people on all forums have dramas with this, so thought i'd try to figure it out. Some of this is lifted from other guys posts, zloybob (via NZ_GolfR), so thanks.
 s.
 Door Lights are just White for MY16-17, not sure about models after thatOriginally posted by Goublin View PostHi Guys,
 I followed the steps below from another page on here. I now have the 10 colours and they work on the dash. The only only thing i cant get to work is the LEDs in the doors. My question is, do the doors change colours in the Passat MY16 or are they white only. Is there a way of checking? I have changed the dials and the colours are there. I just cant figure the door leds out.Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
 Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
 Previous - Passat 206TSI MY17 - Night Blue
 I think what happened VW Australia in their infinite wisdom to keep cost down (or is it profits up) decided to import only white LED's in the door cards. This fits with other things that are missing compared to VW Passats that are available in some parts of the world.
 So today I tried to activate traffic sign recognition through OBDEleven. I tried using their App that uses credits. Not supported. I guess this is why I couldn't do it via long coding either. Strange as others with very similar car have done it. Car is MY18 Alltrack Wolfsburg.MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
 If it's throwing an error it might be helpful to post the exact error...Originally posted by lenny View PostHaving a problem with driver seat memory function.....it is throwing an error that i can see through ODB11, when i clear error it comes back again...memory function has stopped working, i would like to try and avoid going to a / any dealer2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
 Hi guys
 Tried to activate the traffic sign recognition with VCDS on a VW Passat, MY2018, from NZ, with the front camera A5. But even the coding is correct, it doesn't work... There aren't some errores messages, but the camera doesn't recognise the traffic signals. Is there a main problem with this coding in NZ / Australia? Because in Germany it works without any problems...
 Any ideas or somebody who were able to activate it?
 Greetings from Europe
