Originally posted by Dark975
									View Post
VCDS Tweaks
 Can this be done for the Passat Alltrack Wolfsburg? Not a fan of the speedo incrementing by 10 after 80kmh. Rather the speedo above incrementing by 10 after 120kmh...2015 Carnival Yellow Honda S660
 2023 MY23 Nevada White Cupra Formentor VZx
 2024 MY23.5 Moon White Skoda Scala 110TSI Signature
 Yep, changed mine to the R clocks as well. Anyone know why i can't see the long coding option in Central Electrics on obd11? trying to do the HBA mod..... cheersOriginally posted by kaiserky View PostYes it can, I’ve changed to the R clocks on my Wolfsburg.
 Ky2015 Carnival Yellow Honda S660
 Thanks Jap, didn't need it in the end. Got HBA not erroring and enabled now. just have to test it. Anyone managed to get the DRL in menu option going for the B8 passat? Also trying to find the DRL active during turn signal. cheers.Originally posted by Jap View Postthere isn’t any long coding in CE, only adaptions on the newer modules2015 Carnival Yellow Honda S660
 I had worked out how to do the DRL active during turn signals and I wouldn't advise it. It's really hard to see the indicator during the day.Originally posted by FarQ View PostThanks Jap, didn't need it in the end. Got HBA not erroring and enabled now. just have to test it. Anyone managed to get the DRL in menu option going for the B8 passat? Also trying to find the DRL active during turn signal. cheers.MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
 MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
 What is the coding for HBA in Obdeleven? Finally had a play today but haven't seen how to enable this. Also couldn't do the window close when raining as the Adaptation looks totally different. I did enable TMS, R dash (1-9 plus A-D) and turned off nag screen.Originally posted by FarQ View PostThanks Jap, didn't need it in the end. Got HBA not erroring and enabled now. just have to test it. Anyone managed to get the DRL in menu option going for the B8 passat? Also trying to find the DRL active during turn signal. cheers.
 KarlMY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
 Give this a go KarlOriginally posted by Jondalar View PostWhat is the coding for HBA in Obdeleven? Finally had a play today but haven't seen how to enable this. Also couldn't do the window close when raining as the Adaptation looks totally different. I did enable TMS, R dash (1-9 plus A-D) and turned off nag screen.
 Karl
 Select Control unit 09 (Central Electrics)
 Security access
 Access Code 31347
 Adaptation
 1. Fernlicht_assistent – Menuesteuerung Fernlichtassistent – Change to ‘Present’
 2. Fernlicht_assistent – Erweiterte_Frenlichtsteuerung – Change to ‘AFS, FLA, Fernlicht ueber AFS’
 Enter Coding
 Byte 2 – Tick Bit 0 and Bit 1
 Select Control Unit Front Sensor Driver Assist System (A5)
 Enter Coding
 Byte 21 – Tick Bit 5
 Reboot Headunit. Option will now appear under ‘Light Settings’ and pushing the high beam stalk forward will reveal the symbol with an ‘A’ within it.Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
 on the passat alltrack wolfy i think you need to change to this setting:Originally posted by Rooboy View PostGive this a go Karl
 Security access
 Access Code 31347
 Adaptation
 Enter Coding
 Enter Coding
 ‘AFS, FLA, BCM-Fernlicht'
 as mine was previously 'AFS, BCM-Fernlicht'. It seems it recognizes the LED headlgihts as Xenons as per this post.2015 Carnival Yellow Honda S660
 Thanks to Jap for the kind reply.Originally posted by Jap View PostTube version 4 or 5 under dash adaptions but you must have current version of vcds
 Do you think that with this change I will keep the color red and did not alter other functionalities such as interior lighting? Thank you
 It only changes the dials - everything else remains the same.Originally posted by Luca View PostThanks to Jap for the kind reply.
 Do you think that with this change I will keep the color red and did not alter other functionalities such as interior lighting? Thank youIndium Grey Golf 7.5 Alltrack 135tdi Premium - all options
