Does the sign recognition work in your model, or is it completely turned off? If it isn't enabled for the Arteon then you might have the same problem as the Passat owners have; i'm told the GPS data isn't the right type for Australia so it will throw a fault about 1 minute after the car starts, it relates to the lack of proper speed limit data from the GPS maps.
It does work (aside from the warning), but it's a little sketchy as most of Australia isn't road signed to any reasonable standard like other markets. This means you can pickup poorly positioned signs on adjacent roads/freeway offramps. Your car could start braking in the middle of the freeway because you're doing 100km/h and the offramp (which you're not on) has a 60 sign visible from the freeway.
W
I really hope not. DTSR is not turned on but is in some really almost third world countries. So hoping it can work. I have read sime post in which by not turning on fusion between gps and tsr it works apparently ok?
Sent from my SM-G935F using Tapatalk
Hoping also it compares the gps map speed knows there is an offramp and things like that.
Hi All
Did my first obd11 tweek via the app to keep my auto high beam on. It all worked just fine "Whoot". However there are just 4 other apps and i dont need any of them. Would like to turn on traffic signs and auto door lock , but can't translate from the rosstech type info on here. Any suggestions? Taking small baby steps....lol
Hi All
have you got pro?
if you have go into the modules and look around (as long as you don’t press and hold the green tick nothing will be changed) find the adaptions and look through and see how they work, then find the long codings and see how that works, maybe go on the obdeleven boards and read through the how to’s to get more info, then find a tweak you want, go through every instruction in it, see if you can find everything that needs to be changed, if you can then go back and change them with saving by the green tick, check rweak works
have you got pro?
Just read all the tweaks for MY17 Passat B8. (Europe ver.)
I wanted to try setting in 09 Central Electronics / (1) so that I can lock my car with key while engine is running, but it seems like Channel is not available.
My car does not have Keyless Entry, only Keyless go. Anyone can help me how to set-up this feature?
Also, could not manage to set-up Lane Assist (or the ALG) / TJA, anybode care to share the link or the coding?
TJA is vcp coding only or vw if they want to but chargeable either way
interesting you have keyless but not kessy, do you have the kessy door handles?
also with the door locking thing are you looking for access control? As the newer modules have it under different parent names now and it’s now under ZV allgemein, as zv is the intitals of zentralverriegelung which is German for central locking and ellgemein is general
No, I do not have keyless doorhandles (I saw at one of my colleague's MY17 Superb how they should look).
I did not equip my car with Keyless Entry (kessy) because I hate the system, I always push the key button to unlock/lock. For me this system is like having to manually turn the key into the fob to lock the car. I only start the engine without the key.
About TJA - I will ask VW Dealership if they want to activate it.
In the meantime, I will try again to code with vcds:
Yes, as I now remember, I have tried (1) Access control - something with "15" in its name . So I should search for "ZV"
