Tigger73's 125TSI Tiguan Build Thread
  • Originally posted by Lucas_R View Post
    If you pull up at the lights next to a manual Golf R/Audi S3 you will give them a very good run for their money with a 5.8sec 0-100kph time.
    Though I doubt I'll be using LC at the lights. Sitting with the car hitting the 3,000RPM rev limiter waiting for the lights to go green is a bit try hard if you ask me.
    Due to not wanting to kill my clutch, ive only done the 0-100kph dash a few times, but i think it was 5.68sec was my best according to my P3 guage. Could probably go a bit faster if i reduced mechanical sympathy, but im still on my stock clutch, and dont want to push my luck.
    Although OBD port timers are good, I ran some back-to-back times with my Auto-polar FIS+ vs Gtech and I know which time I'd have more confidence in. Not that 0-100 times are really that important just nice to know what it is with some reasonable sort of accuracy.
    Amazing how much of an advantage the DSG gives a car off the mark and through the first few gears.
    It's certainly an advantage for the ungifted driver.
    My mate has a Mk5 GTI thats stage 2 and DSG and off the line we are neck and neck. Once we are up and moving (eg rolling start) then i can pull away, but off the mark the DSG and lighter weight in his GTI make a big difference.
    Yes did these times with a fellow Mk6 GTI driver and the Tig does lose out a bit due to its weight - it's like adding a couple of extra people into the car. Kind of takes the edge off things. Though he was impressed with the ability off the line in greasy conditions later in the day and his next car will be AWD for sure
    - Tigger73's 125TSI Build
    • Good time there Damien, about exactly where it should be for a Stg2.
      Actually, unless you use the LC, the manuals will almost always (at least 95% of the time) win the traffic lights GP. The hesitation off the line in non LC mode costs the DSGs equipped cars too much time to make up in the (normally) short space available.
      I watched with amusement a 370Z giving a R a hiding 3 lights in a row the other night .... even though they are almost identical in their official 0-100km/h times, the moment the lights turned green the 370Z jumped 3 cars ahead and kept that distance till the next brake point. DSG did nothing to beat the good old fashioned manual. Poor fool in the R kept on trying and the 370Z kept on winning ... lol
      • No turbo lag + manual + no AWD bogging down in the 370Z is a winner. If the R was a manual it would have been good to see the difference. Or if the R used LC it might have been a different scenario. Unfortunately the LC is such a process that unless you have a planned race with plenty of time to prepare yourself (eg 1/4 mile drag strip or a runway etc) then you don't have enough time to set it up. Traffic light GP's are not the right place.
        Your right Damien - using LC at a set of lights would look pretty silly wouldn't it.
        2015 Audi SQ5 - SOLD
        New car incoming...
        • Originally posted by Sharkie View Post
          Yes stomping the right foot is about 1 second slower than with LC and it's all in that first bit off the line that you lose all the time. So even if you're up against a "slower" car, if it's faster off the line the DSG car is going to lose every time. Like your friend inthe R who was up against the 370Z.
          And yes running LC at the traffic lights GP is a bit over the top.
          • Originally posted by tigger73 View Post
            I was just an amused spectator .... lol .... heading home on the bike latish 1 evening, this scenario unfolded in front of me .... so at the 4th set of lights, I had to show them the difference between 6s 0-100 and sub 3s 0-100. Never saw either again after that ....
              Love seeing road bikes take off from a standstill....even without trying they are miles ahead from the rest of the traffic. Would love to have a run against something quick to see it pull away from me. I've run a few Harley's (which are so damn slow despite that horrible noise they make) but never run anything worthwhile.
              New car incoming...
                I was said Mk6 driver. I wasn't just impressed in the wet - the way this Tig launches from a standstill is genuinely impressive. The DSG tune helps a lot as well; the LC on my GTI has a vague and inconsistent limiter (nothing you can bash against) and no traction besides, but this pops away right at 3k rpm and gets away with just a hint of front wheel slip. It looks super-effective from the outside, and feels properly strong from the passenger seat.
                You do feel the extra weight of the Tig (over a Golf) when accelerating hard above, say, 60km/h, and there's no question that it does get breathless in the higher reaches (just like any k03), but that's not taking anything away from this car - it's a mighty impressive bit of kit. Looks the goods too.
                • Tigger73's Build Thread
                  Thanks for sharing the drive and also use of the timing gear. I'll have to see if I can edit the video and get this up later in the week.
                  Not much you can do about the weight of the Tig as a lot of it is built into the chassis. Only thing you can do is add more power
                  Reality is it's a pretty well-balanced package at the moment. K04 would certainly keep it pulling higher in the rev range but then I'd probably also have to look at upgrading the brakes.
                  And then if I'm not tracking it then it's questionable as to what real world value this is going to provide. Other than bragging rights. Just trying to justify to myself not spending the money
                    My recommendation would be to stick with the K03. It's going to be more lively down low (good for daily driving), will save you a ton of cash, will put less strain on the drivetrain, will be easier to insure, and will provide less of an incentive to pull big speeds and get booked.
                    If you were regularly tracking the car, or taking it down the strip, my recommendation might be different. But we have no full-time strip in SA, and Mallala is a fairly horrible track too, so... pass.
                    • Originally posted by AdamD View Post
                      Yes given the hills is pretty much an 80km/hr zone there's not a lot of point I agree.
                      • Another possibility is to go a hybrid K03/K04 turbo. Better down low than a K04, better up high than a K03. That would however require a custom tune (Custom Code possibly?) which may or may not be a route you want to explore at this time.
                        I have driven K04 TSI's and to be honest not much of a loss down low IMO. Not enough to not make me want 1 anyway
                        I will be going K04 on the Amarok in due course .....
                          I hear you. Just trying to justify not spending the money. And you're not helping my cause.....
                          • There's a guy in USA who removed his K03 from Mk6 GTI and had it ported and polished. Got good gains from it (proven on dyno and 1/4 mile). I'll find the thread.
                            Another guy stole his idea and is now doing the same with a K04 on a Mk6 GTI.
                            Edit - here's the thread with pics: http://forums.fourtitude.com/showthr...-tsi-ko3-turbo!
                            New car incoming...
                              I'm gathering this wouldn't require any change to the tune then.
                              Be interesting to find out the cost... Though sounds like you still may need tore move the turbo which is not a small job.
                                This guy did the work himself so cost was not much. But yes, turbo needs to be removed, which is a lot easier to do on a FWD GTI. May as well move to a K04 (and port that before installing it) i guess.
                                This is the guy who just did the port and polish on a K04. He then had the manifold ceramic coated and now is putting a turbo blanket over it to keep heat out of the engine bay. http://www.golfmk6.com/forums/showth...88#post1472588
                                New car incoming...
