Originally posted by DoggieHowser
View Post
Flappy paddles steering wheel in Tiguan.
I've got a flappy paddle steering wheel on the way..... type R badge but without airbag.
Next question is how to figure out which airbag to get as there seems to be some differences on the part # on the airbag (and possibly cables???)
Any suggestions from people that have already been down this path.
Also my other concern is buying off ebay/net and getting a knock-off (non-genuine) part.
As it's a pretty critical piece of equipment (like you want it to work when you need it to), I'm a little concerned buying stuff from Hong Kong.
I've noticed that there are a few people selling airbags from Europe but not sure if anyone has had any experience with any of these.
Should I wait until I get the wheel to order an airbag or are all Mk6 airbags the same?
This is pretty much where i am stuck..... you can find stuff for sale on ebay pretty easily but who are the genuine sellers?Originally posted by tigger73 View PostAlso my other concern is buying off ebay/net and getting a knock-off (non-genuine) part.
I not only want to change my steering wheel for an R wheel with paddles but i also want to get myself a sat nav unit but dont know who sells the right gear
If the price matches what we paid and the seller has >99% feedback then you should be fine. Photos help (make sure any watermarks match the store name and aren't obviously copied from elsewhere). Part numbers will often change but this doesn't always mean newer versions are incompatible. Just make sure the shape of the airbag and the clip system matches. RNS510's are best purchased from the UK, have AUS maps already loaded, show a security code card, and cost around $1000-1200.
OK my "R" steering wheel with flappy paddles arrived today. Next step is to get the right airbag and cable to suit.
I spoke to my local VW dealer (spare parts dept), however they were not prepared/able to assist. First they don't want to give advice to something that is non-standard as they don't want it to come back and bite them in the rear end. The other reason I think they don't want to help is they know if they quote me the part number that works, I'll go and source it somewhere else at 1/5th the price.
Strike 1.
So I've checked around online and there are a number of airbags/cables advertised with very similar part numbers 5K0 880 201 A/B/C/D/E/F/G/H etc (only the last letter changes). The only problem I have is to know the right one to buy and what the last letter means (and if this is going to matter).
If anyone can shed some light here that would be greatly appreciated.
Second can any of you guys that have already done this modification tell me if you used the Tiguan wiring or if you used the Golf Mk6 wiring for your airbag? i.e. if I need to buy and airbag with the wiring harness or if I just need to get the bag.
I'm hoping that if someone can provide the answers it will help other people looking to do this mod but not knowing where to start (if you can't buy a wheel with an air bag)
I thought I stated that in my first post in this thread that existing Tiguan wiring harness works.
Again, based on my own experience you just need to get the bag.
If that fails, then you just buy the harness. No loss.MY11 Tiguan 147TSI (SOLD)
Thanks - wasn't sure which harness you ended up using.Originally posted by aussietig View PostI thought I stated that in my first post in this thread that existing Tiguan wiring harness works.
Will do as you suggested and try the Tig harness first. Worst case I'll have to buy the Mk6 harness.
Now just to work out which airbag to get....
I used my existing wiring in the Golf as well, no changes there, no issues.
Last letter in part numbers usually just means incremental revisions over time (at last as far as bluetooth and RNS510 part numbers go)
Yeah so the million dollar question is are the various revisions compatible. The wheel I've got is brand new - date stamp is 05/2012. Do you know what the airbag has to be compatible with? i.e. what bit is it talking to and what is going to throw up a fault?Originally posted by Ryan_R View PostI used my existing wiring in the Golf as well, no changes there, no issues.
I've had a look at the wheel and there's a 5 pin plug in the base of the steering wheel (that the wiring harness from the airbag goes into) and the other cables from the multi-function buttons end up around here as well. Is this just a connector for all the cables to feed back further down the steering column or is there some "smarts" under the bit of black plastic?
At the end of the day all I ned to know is do I get an airbag to match the electronics of my Tig or to match the electrics of the steering wheel?
I'm guessing there's revision numbers for a reason... any idea how to find out what the various updates/changes would be and then if there's any compatibility issues.
Local VW spare parts guy has everything tied back to a VIN so that really doesn't help that much.
If it was me ... I'd get the airbag that has the similar manufacture date as the wheel. That's just the most logical answer.Originally posted by tigger73 View PostYeah so the million dollar question is are the various revisions compatible. The wheel I've got is brand new - date stamp is 05/2012. Do you know what the airbag has to be compatible with? i.e. what bit is it talking to and what is going to throw up a fault?
So suggest you ask sellers the manufacture date of each airbag revision they're selling.
Suggest you study the pics again in my first post. I had a D version airbag and was supplied a A version wiring harness.
But I didn't end up using the A version wiring harness supplied and used my own.
Now based on logic again and go through the pics in this thread again, Ryan R mentioned his airbag clip was different to mine.
So it is possible that's just what the revisions in the airbag part numbers reflect.
More importantly, I think you need to have the right SWCM. Again look at my first post for the part number.
I would hazard a guess, that you need one at least the same or if not higher than me in the last letters.
The million dollar questions here are:
What MY is your Tig?
Do you have white MFD and multi-function buttons on your existing SW?
But post up your SWCM part number (once you find it using VCDS) and I can give you an opinion on that while you're still undecided about the airbag.MY11 Tiguan 147TSI (SOLD)
I'm pretty sure it would fit as a lot of the Mk6 steering wheels are advertised to fit scirocco's too. From recent experience if you can try and get the wheel and airbag together (though a lot of ebay sellers sell them separately).Originally posted by Dr freedom View PostI was looking at a sirocco flat bottom wheel yesterday.
I think it would also fit.. can anyone confirm?
The other thing is make sure the steering wheel has got flappy paddles otherwise it's a pointless exercise.
I got mine from this seller - ccc2_123. At the moment he's selling a GTI wheel without paddles:Originally posted by Leec33 View PostTigger.. Where did you get the wheel from? Do you know if they have anymore?
OEM VW Golf, Scirocco , Steering Wheel NICE | eBay
The guy says he's from Germany but the shipment actually came from Romania. Though I didn't have any problems - item was sent with tracking and took about 2 weeks to arrive. Only thing is I have to find an airbag now...
Well if you look at my first post again, that is the guy I bought mine from and recommended people to contact.Originally posted by tigger73 View PostThe guy says he's from Germany but the shipment actually came from Romania. Though I didn't have any problems - item was sent with tracking and took about 2 weeks to arrive. Only thing is I have to find an airbag now...
At the time, he didn't list any airbags on eBay and I just asked him.
So you sure he can't supply an airbag? Doesn't hurt to ask if you never did.Last edited by aussietig; 29-06-2012, 11:09 PM.MY11 Tiguan 147TSI (SOLD)
