6 or 12 month for minor/oil service interval? MK7 R
This topic is closed.
  • 6 or 12 month for minor/oil service interval? MK7 R
    Had the last minor service done 5 months ago, and have just got the oil service due in 30 days light come up, which would line up with 6 months. I've only done about 7,000kms since.
    Is it really due after 6 months, or can I wait until the next scheduled service (12 months)?
    Not fussed either way, but all my previous VWs have had 12 month servicing intervals.
    '18 MY18.5 MK3.5 Octavia vRS245
    Previous - 2015 MY16 MK7 R, 2010 MY10 R36 DSG, 2010 MK6 Golf GTI DSG // APR Stage 2, 2006 MK5 Jetta TFSI DSG // Revo Stage 2, 2006 MK5 Golf GTI Manual
    @whichonetoget: Hi. There's lots of mystique about service intervals - but the "standard" advice for these cars from the manufacturer is the earlier of 15,000 kms or 12 months.
    Of course, you could always shorten these thresholds - but my own personal opinion is that the expense ain't worth the cost (even if you DIY)
    Don
      @whichonetoget and DV52
      Hi. An Oil analysis would take the mystery out of whether the oil is still in service?
      Cheers Al
        VW's recommended schedule is 12months or 15,000km whichever comes first.
        Some sneaky mechanics (non-VW) sets it to 6 months/10,000km to get you to come back 2x in a year ..... it is not necessary.
          I agree with Don & Sharkie, given the long life additives in the correct oil for VW's 15,000/12 months should be OK unless you have severe usage conditions (all very short trips, tuned engine, track/drags etc)
            I have both my T-Cross and my Mark 6 Golf serviced at the dealer. The T-Cross is normally used for regular trips from the Sunshine Coast to Brisbane while the Golf is a used for local short running. The T Cross is serviced every 12 months and the other one has the oil changed every six months to compensate for lots of short/cold runs.
              Both our VAG cars are used for short trips on the Sunny Coast and have only ever had 12 month services with no detriment. Prev 2 did the same and had the same with same result.. Overseas they use the same LL oil for 36 month services so cant see why you would need 6 month changes
                @Hillbilly: hmmm....... as I said in my first reply "there's lots of mystique about service interval" and I agree with your assertion that there isn't a "need [for] 6 month change".
                However, these decisions are not about satisfying a technical "need"
                Instead, the choice to shorten (or even to extend) the manufacturer's recommendation is fundamentally a "value" judgement - it's not a technical matter. The car owner perceives that there is a positive advantage in the added expense of a smaller service interval.
                Now, because this decision is ostensibly a risk management exercise, it's difficult to actually prove the case either way - because the perceived advantage of a shorter service interval is what risk analysis calls "a negative value proposition" (i.e. additional peace-of-mind is impossible to disclaim).
                So and IMO of course, shortening the service period does have positive advantage for the car owner - it provides added reassurance that engine wear-and-tear is reduced!
                Now, we may not agree that the value of a shortened period is justified - but in making that claim, we are adopting a different definition of "need"
                Don
                  Well all I can say regarding wear is that in 4 VAG vehicles since 2010 the only time Ive added oil was when the muppet at service filled it short. So seems the wear was negligible. If an owner wants to spend money unnecessarily fine, their car their money.
                    Unless you run the car for over 200,000 km with no wear issues it is difficult to be certain either way.
                    If you change cars at 100,000 km you are unlikely to notice a difference, unless you do an oil analysis (as suggested by Al) or a compression test or tear down inspection looking for wear.
                      oil change every 15 - 20k is fine
                        Stupid comment if car is in Warranty as if anything happens and VW are wise to it they could deny a warranty claim because you failed to abide by the terms in letting it run so far over..
                        Also is stupid in cases like mine as car is nearly 4 years old and has only done 13000km. So by your assertion I can leave it for another 2 years or so as thats about how long it will take me to do another 7000km.
                        It has been serviced annually as by the book as oils deteriorate over time and should be done at recommended time or Km's whichever comes first. They give a month or so grace if they are busy or in my case was overseas.
                        Get Real.
                          also some people drive their car more than 7000km per year.. 20 - 40k per year for driving extended distances to work and travel. not just driving around their village to woolies. in that case the oil is good for 15 - 20k changes.
                          everyones circumstances are different so dont make it all about yourself
                            so. vw recommended oil change 15,000km / 12months.
                            but you guys are trying to tell me its stupid to say doing and oil change at 15 - 20,000km within 12 months when the original post is asking if 6month 5,000km is too short?
                            if your getting oil serviced on schedule from VW / warranty - 15,000 - 12 months then you dont really have to worry about your warranty being written off do you?
                            but if your warranty has lapsed or you have a 2nd hand car then its safe to change your oil every 15 - 20k or every couple years.
                            as for PETEMAC. if youre worried about moisture in your engine then id say you have bigger problem (seals, gaskets, leaks) than the oil in your car or i recommend not diluting your oil with water
                            cheers
                              No, changing your oil every couple of years is not recommended and bad advice IMHO. The mileage that you do is not the only contributing factor to your oil deteriorating, and hence the frequency with which you should change your oil. There's a raft of info available out there on this.
                              cheers
                              As above, there's plenty of info out there on this. Repeated short trips can result in small amounts of condensation in your oil. We're not talking litres... only very small amounts, but it's there.
