Legends, thanks guys.
Why you need to use 504/507 oils in FSI/TSI/TDI engines!
Supercheap have 5L Castrol Edge 5w30 VW 504/507 spec for $63...any good, or better to spend more on something like the Liqui Moly?
Castrol Edge Diesel DPF Engine Oil - 5W-30, 5 Litre - Supercheap Auto
What are your thoughts on Sakura oil filters?
For a 2009 Caravelle, 2.5 TDi 96kW.
That is the good approved stuff and is as good as you need and meets the same specs as the others you mentionOriginally posted by blaast View PostSupercheap have 5L Castrol Edge 5w30 VW 504/507 spec for $63...any good, or better to spend more on something like the Liqui Moly?
Dont know about the filtersLast edited by Guest001; 19-01-2017, 01:29 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
The oil is fine, but the filter is garbage. The O-ring is not thick enough and will cause the cap on the oil filter housing to leak. Plus, more often than not, the filter will probably collapse over time.
Try and avoid brands like Ryco, Wesfil and Sakura on these. They're crap.
A genuine filter for these - 071115562C is only $25. Alternatively, OEM brands like Hengst, Mahle, and MANN are decent too, and are a little cheaper.'07 Transporter 1.9 TDI
'01 Beetle 2.0
I was using the 5w-30 Castrol 507 dealer approved oil (change twice a year for 3.5 years) and found that it would drink the oil. Around 1L per 2500-3000km. I also found my Renault ClioSport would drink Castrol oil whereas when I ran Elf it didn't consume any (10,000km changes)
I recently (one change 5,600km) switched to Liqui Moly Top Tech 4200 and it has used only100mL in 5,000km
Wonder if this has been the experience for others?
It varies from model to model.Originally posted by minke View PostI was using the 5w-30 Castrol 507 dealer approved oil (change twice a year for 3.5 years) and found that it would drink the oil. Around 1L per 2500-3000km. I also found my Renault ClioSport would drink Castrol oil whereas when I ran Elf it didn't consume any (10,000km changes)
I also have great experiences with Elf/Total oils.
Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Thanks for that advice.
I bought a couple of Sakura filters a year ago and used one at the time and have just changed the oil using another.
When I took the filter out I noticed that the 'fins' were twisted, but was told by someone that this is normal due to the pressure exerted by the oil.
I was skeptical about this, and it seems l should have been moreso!
4100 Liquid Moly appears to only be in 5W-40? This is fine for Skoda Octavia RS 2012 TSI Manual and won't void warranty even though it's not VW 504/507?Originally posted by Umai Naa!! View PostTDI is 4200 only.
Petrol engines can run 4100, or 4200.
TOP TEC 4100 | 5W-40 – LIQUI-MOLY AustraliaLast edited by donweather; 19-01-2017, 01:19 PM.
Pretty sure you're correct.Originally posted by Umai Naa!! View PostI don't have 100% confirmation from VW Aus, but I believe the 502/505-spec 5W-40 oils are ok in the petrol engines.
Liqui Moly Toptec 4100 is 502/505-approved, as is Penrite HPR-5.
However the 502/505 isn't suitable for extended oil change intervals i.e. 25,000km. Not that you'd want to leave your 504/507 oil in there for that long anyway as allowed by VW in some countries.MY07 Red GTI 3 Door
As we have 12 month or 15,000k (whichever is first) oil changes it wouldnt be a problem hereOriginally posted by Johnbu View PostPretty sure you're correct.
Our Polo TSI manual specifies 502/505 or higher I just run them both on the 504/507 to save having two types hanging around.2021 Kamiq LE 110 , Moon White, BV cameras F & B
