Originally posted by bradsm87
View Post
Why you need to use 504/507 oils in FSI/TSI/TDI engines!
Because that's what the dealerships and VW AU say to use. I thought I knew the manual fairly well and I haven't seen the bit you are referring to. Can you post it?carandimage The place where Off-Topic is On-Topic
This is my MY18 GTI manual but I've seen someone with a Polo show the same thing. Where fuel does not meet EN 228, 502 oil must be used according to the manual.Originally posted by brad View PostBecause that's what the dealerships and VW AU say to use. I thought I knew the manual fairly well and I haven't seen the bit you are referring to. Can you post it?
I can't explain it.
In my 2007 model it's simply "variable = 504. fixed = 502. 504 can be used on fixed interval" No mention of fuel quality.
I'd suggest you ask the VW AU tech heads. Or direct your question directly to Wolfsburg.carandimage The place where Off-Topic is On-Topic
None at allOriginally posted by samps View PostHey guys. B9 RS5 owner here. Looking to do interim oil changes (6 monthly). Any reason why I wouldn't use 5w30 504 spec oil given temps in Melb won't be below 5c for the next 6-9 months?2021 Kamiq LE 110 , Moon White, BV cameras F & B
The irony of this from VW is, that using a 504.00 or 507.00 oil with the lower quality (higher sulphur) fuel available here, means that the vehicle will no longer meet the ADR for the emission requirements that the vehicle model achieved.Originally posted by bradsm87 View PostThis is my MY18 GTI manual but I've seen someone with a Polo show the same thing. Where fuel does not meet EN 228, 502 oil must be used according to the manual.[ATTACH=CONFIG]50744[/ATTACH]
