Originally posted by Corey_R
View Post
The concept of "drone" and what people consider "drone" varies from person to person, but the "flapper valve" which has just been discussed above means that it's relatively quiet when you're just cruising.
Having said that, a "real" 115km/h (about 124km/h on the speedo) will mean the revs in 6th are around/just over 3000rpm. It would definitely be quieter if it had a 7th gear.
Sigh.Originally posted by Corey_R View PostThe concept of "drone" and what people consider "drone" varies from person to person, but the "flapper valve" which has just been discussed above means that it's relatively quiet when you're just cruising.
That's exactly what I want to know. It's not quiet when travelling at highway cruise speed.
Would Milltek exhaust be quieter when cruising?
We just did a return trip to QLD (very regular trips). The R is quieter than our GTI MKV at freeway speeds.Originally posted by cavinsoo View PostRather than opening a new thread, I'll stick my question here.
Is there any exhaust drone when cruising on highways in between 100-115kmh? Stock exhaust.
Thanks.
That is both road noise and exhaust/engine noise. The GTI used to drone for rear seat passengers and noticeable in the front too. Both unmodified.
However, if you open the throttle to overtake etc, yes, the R is louder, in a very nice way
Thanks for the reply.Originally posted by Candyman View PostWe just did a return trip to QLD (very regular trips). The R is quieter than our GTI MKV at freeway speeds.
Might I suggest a large sedan rather than a sports hatchback for sir?Originally posted by cavinsoo View PostSigh.
Would Milltek exhaust be quieter when cruising?Audi S3. Sold
Golf R. Sold
Citroen DS3 Dsport. Sold
2016 Skoda Octavia RS Wagon.
Had a weird thing happen to me this afternoon. The car is a manual so that probably excludes about 98% of you from being able to know what i am about to explain
I took off quite quickly from a standstill up to about 30kph (1st gear only) and then stopped again at a giveway sign. Foot on clutch, no accelerator but the RPM's hovered at around 3000rpm for several seconds. I tried blipping the throttle to settle the revs but it didnt make a difference.
After a few seconds the revs dropped again to normal idle and i pulled away. Ive never had this happen before but i have also never driven off and then braked in that matter either. I assume it has something to do with the electric throttle? My foot was certainly not on the acellerator.
No drone. As quiet as stock. Mine's non-res too. Love it!Originally posted by cavinsoo View PostSigh.
Would Milltek exhaust be quieter when cruising?| Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
That has happened to me once or twice.Originally posted by Lucas_R View PostHad a weird thing happen to me this afternoon. The car is a manual so that probably excludes about 98% of you from being able to know what i am about to explain
I have no idea what caused it.
It's on the list of things to ask at my service in about a month.Audi S3. Sold
Golf R. Sold
OK, have searched the forum and Google. Maybe my keywords aren't right
My RCD510 used to not autoplay from SD cards and my iPhone
Now it autoplays as soon as I connect the phone via MDI or if I insert an SD card
This isn't the bt autoplay issue (I am aware of that setting and turning it on or off made no diff)
I haven't changed any settings, can't find any that control this and nothing in the manual that I can find8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
