Golf R Observations and Questions
  • Originally posted by BockeyT View Post
    Hi Everyone,
    Can anyone suggest tire pressures to run for track days for the Golf R with Dunlop Maxx GT's 18"? About 20C ambient.
    I have tried 42 cold. 35 cold. 42 is too high for the rears as they crown too much. Handling seems poorer at 35. Any suggestions? I need to stick to road tires, can't change to R spec tires for track days.
    I have had the R on the track twice now. It is very quick for a road car. At Qld. Raceway I am getting times similar to a couple of Nissan Skylines on R Spec tires and I am a novice on the track. I am very impressed with the performance AND so much FUN!! I even find leaving it in Sport mode does the trick regarding keeping the revs in the power band. A truly brilliant car.
    What times wre you getting for the sprint, clubman, & national tracks mate? I gather yours is stock?
    Big Dave also posted something about times @ QR but never replied with what they were.
    Edit: Also what is the top speed you are seeing down the front straight?
    Golf R - 77TSI engine transplant, 91ron tune, & a crochet rug on the parcel shelf
    • Good info adzy but not what I was interested in
      I managed to watch Big Daves run on the clubman and he was doing 69-70's which isn't bad. Some funny gearchanges thru the corner though from the DSG ???
      • Oops LOL........ I see what I did there I read BrockyTs post
        APR S2/Whiteline/H&R/Enkei/Carbonio/13.68@101/Winton-1:44.52
        • Loving the R in the rain
          Considerable rain out west today with localized flooding
          The R was composed and planted under moderate acceleration at the lights and out of corners. Never had any concerns at all.
          None of the axle tramp and front wheel spin like we used to get in our GTI.
          • Used the horn for the first time today and was expecting a wimpy noise but was surprised that a small car has a horn with some balls!!
            Golf R, Rising Blue, 5 Door, DSG and some extra fruit.
            Viagra on 4 wheels !!
            "If you can't fix it with a hammer then it must be an electrical problem"
            • Originally posted by Rob_R View Post
              I use mine all the time to honk cabbies who think the road belongs to their grandmother! Cabbies annoy the **** out of me. Never had problems with them 5 yrs ago!
              | Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
              • unusual, and possibly dumb, question .. but I'll go ahead and ask it anyway
                .. the very sexy, deep, throaty sound that you hear for the first second or so when you start up the R - what the frack is it exactly? ie. precisely what engine components are responsible for this awesome sound??
                never fails to get me excited
                - 2006 Audi B7 RS4 sedan, black, APR supercharged
                - 2008 Audi B7 RS4 avant, silver -- 2002 Audi B5 S4 vagwagon, ming blue
                - MY12 OCTAVIA vRS Wagon | DSG | revo | Eurojet DP | Milltek catback | KW V3's | 18x9 -45 Rays VR G2's | 18x8.5 -45 A8 Flat Fives | Kumho KU36 245/35 | Superpro ALK | ECS Stage 3 BBK | ECS eng mount | ITG Maxogen | DTM front splitter | SB
                • Originally posted by bluefrog View Post
                  All the usual components of an internal combustion engine, however on a cold start the RPM's are higher and both exhaust outlets are open, hence the deeper throatier sound (I think this is what you're referring to?)
                  I like this sound too, and usually start mine with the garage door closed so I get more of an echo
                  WLF127
                  • Originally posted by shakespeare View Post
                    Both exhaust outlets open? What's the go there?
                    • The Golf R has a "flapper valve" on the exhaust. One of the pipes only opens over a certain rpm/under a circle throttle load, thus allowing the car to have a high level of exhaust flow when needed, but also to be quiet(er) when that flow isn't needed.
                      • very interesting and good to know .. thanks guys
                        • Originally posted by Corey_R View Post
                          Cheers Is this unique to the R or do the GTI and Audi's have it as well?
                          • I'm not aware of a A3 / S3 model which has it, and within the Golf range it's unique to the R.
                            Many manufacturers use them these days in their performance models though. Allows them to get around the noise regs but still provide a meaty exhaust sound.
                            • Cheers Corey
                              • Found this, it relates to the R32 but maybe the the same for the R -
                                That's not a vacuum pump, its a vacuum reservoir with a solenoid valve.
                                The MK IV Flapper gets its vacuum supply from the engines intake.
                                The Flapper is held closed(Quiet) by vacuum, and opens(Loud) when that
                                vacuum supply is shut off.
                                The vacuum line runs from the intake to the reservoir/valve, then to the Flapper.
                                The solenoid valve is electronically controlled by the ECU to shut off the
                                vacuum supply to the Flapper when the rpm gets above 3200-3500rpm in
                                3rd, 4th, 5th, and 6th gears.
                                I would think the MK V operates off of a similar system. Has anyone chased
                                down that vacuum line that runs to the Flapper to see where it goes?
                                And this, more of the same -
                                BTW, this was all discussed some time ago over on the R32 forum on tyresmoke.net.
                                One theory proposed there, is that the MkV R32's flapper logic is slightly different than the MkIV, as follows.
                                MkIV
                                off - flapper open
                                idle - flapper closed
                                Below 3500 rpms or 45 mph, flapper closed
                                Abvove 3500 rpms and 45mph, flapper open
                                MkV
                                off - flapper open
                                idle - flapper open
                                Between idle and 3500 rpms + 45 mph, flapper closed
                                above 3500 rpms and 45mph, flapper open
                                Basically they wanted to give it a little more burble at idle so
                                they left the flapper open. The only difference is in ECU logic.
                                The operation of the flapper itself is the same. No vacuum, it's open.
                                Apply vacuum, it's closed.
                                Means flapper mod is the same as well. Clamp line, or pull it off
                                and plug it, or interrupt the signal wire from the ECU, and it's open.
