Golf R Observations and Questions
  • Originally posted by Corey_R View Post
    I'm not aware of a A3 / S3 model which has it, and within the Golf range it's unique to the R.
    Many manufacturers use them these days in their performance models though. Allows them to get around the noise regs but still provide a meaty exhaust sound.
    8P Audi S3 has it too!
    • Rather than opening a new thread, I'll stick my question here.
      Is there any exhaust drone when cruising on highways in between 100-115kmh? Stock exhaust.
      Thanks.
      • The concept of "drone" and what people consider "drone" varies from person to person, but the "flapper valve" which has just been discussed above means that it's relatively quiet when you're just cruising.
        Having said that, a "real" 115km/h (about 124km/h on the speedo) will mean the revs in 6th are around/just over 3000rpm. It would definitely be quieter if it had a 7th gear.
          Sigh.
          That's exactly what I want to know. It's not quiet when travelling at highway cruise speed.
          Would Milltek exhaust be quieter when cruising?
          • Originally posted by cavinsoo View Post
            Thanks.
            We just did a return trip to QLD (very regular trips). The R is quieter than our GTI MKV at freeway speeds.
            That is both road noise and exhaust/engine noise. The GTI used to drone for rear seat passengers and noticeable in the front too. Both unmodified.
            However, if you open the throttle to overtake etc, yes, the R is louder, in a very nice way
            • Originally posted by Candyman View Post
              Thanks for the reply.
                Sigh.
                Might I suggest a large sedan rather than a sports hatchback for sir?
                Audi S3. Sold
                Golf R. Sold
                Citroen DS3 Dsport. Sold
                2016 Skoda Octavia RS Wagon.
                • Had a weird thing happen to me this afternoon. The car is a manual so that probably excludes about 98% of you from being able to know what i am about to explain .
                  I took off quite quickly from a standstill up to about 30kph (1st gear only) and then stopped again at a giveway sign. Foot on clutch, no accelerator but the RPM's hovered at around 3000rpm for several seconds. I tried blipping the throttle to settle the revs but it didnt make a difference.
                  After a few seconds the revs dropped again to normal idle and i pulled away. Ive never had this happen before but i have also never driven off and then braked in that matter either. I assume it has something to do with the electric throttle? My foot was certainly not on the acellerator.
                    Sigh.
                    No drone. As quiet as stock. Mine's non-res too. Love it!
                    | Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
                    • Originally posted by Ideo View Post
                      drole
                      • i have a manual... clutch in.. revs won't go over 4,000rpm when at a stand still... won't let you dump it..
                        nom nom nom
                        • Originally posted by Lucas_R View Post
                          That has happened to me once or twice.
                          I have no idea what caused it.
                          It's on the list of things to ask at my service in about a month.
                          Audi S3. Sold
                          Golf R. Sold
                          • OK, have searched the forum and Google. Maybe my keywords aren't right
                            My RCD510 used to not autoplay from SD cards and my iPhone
                            Now it autoplays as soon as I connect the phone via MDI or if I insert an SD card
                            This isn't the bt autoplay issue (I am aware of that setting and turning it on or off made no diff)
                            I haven't changed any settings, can't find any that control this and nothing in the manual that I can find
                            • My R has now done 5000km I just checked the oil levels and its pretty low. What oils do you guys recommend for a top up?
                              Candy White Golf R DSG MDI Bluetooth & Bluefin installed!
                              • Any 504.00 but 502.00 will do at a pinch. They are the magic numbers to look/ask for.
