  • Plus, the resolution of the RCD510 display is only 400 x 240 pixels, which is too low for DVD/TV/Video playback. The RNS510 display is 800 x 480 which is fine for DVD/TV/Video playback.
    • Originally posted by REXman View Post
      You mean even the poorer, humble not-as-good Golfs can get in on the action?
      That's awesome!
      Yes assume it works with all Golf's fitted with an RNS510
      Mine has factory fitted RCD510 with camera but haven't worried about hooking up video, i'd get the RNS510 first and as corey mentioned the res is better.
      • I use the Golf Wagon 77TDI's in my fleet, they have a feature which I'm wondering is available in the R i'm about to lay my eager hands on, that is when you leave the car and lock in remotely the windows roll up and when you unlock and hold the button down the doors unlock and the windows go down about a third????.... Morning Camilla is safe, dockside in Bris with:
        Black 3dr, DSG, ACC, 19" Black Talladega's, Heaps of Goodies - Double Tint - APR Stage 1 - Delivered and Lovin' my R
        • Originally posted by weewilly View Post
          Yes, this works on the R. Also opens/closes sunroof in coordination with windows. Windows should go right down while holding the open button down?
          It's handy... Especially on a hot day, just before jumping in, release the steam! Also good when leaving car in a hurry, don't need to press buttons/knobs inside, just walk away and hold button down.
          This is pretty common on euro cars. Have had this feature on Renault, Alfa and Peugeot.
          • thank you ratedr
            • Thanks boys, I thought that would be the case.
              How big of a job is it changing the unit? Is it as simple as removing the old and adding the new??
              Wouldn't mind changing the unit but won't bother if it requires a lot of work.
              GOLF R Stage 2+
              MK3 OCTAVIA vRS WAGON
              • Hi masev, I have a VCDS cable if you need to do the recoding...
                MY11 Rising Blue 5dr DSG Golf R
                • Thanks Simon, appreciate the thought - Hopefully, the installation isn’t too much of an issue and I can take you up on the offer
                  Has your car landed yet? Can’t remember whether you were on the Morning Camilla or not??
                  I ended up contacting Craig from Autografika (nice bloke) and will hopefully organise the Venturshield in the next couple of weeks. He also mentioned that they’ll consider working on a weekend, which would be ideal when picking up on a weekend.
                  So close now!
                  GOLF R Stage 2+
                  • Yup - I'm on the Morning Camilla too.
                      All the VW/Audi's from the past 3-4yrs I've used have had the feature, if you have a sunroof it will do that too
                      • IIRC, somewhere in this forum states that if you lock your car with the sunroof open, it won't auto shut when it rains - in other words the rain sensors are only for the wipers. Is this right?
                        | Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
                        • Correct, but if you have VCDS you can turn that feature on (also does the side windows).
                          Audi A3
                          • Just FYI the Audi S3's sunroof could be closed [as could the windows] with the key fob.
                            However,for some inexplicable reason,from the "Facelift"[late 08] only the windows close-not the sunroof.
                            Nobody has been able to get to the bottom of this as to why.[I don't care-mine's pre-facelift]
                            Just hope the Golf R's not the same.....
                            • I notice golf r only has one touch power window for driver... Disappointing... Most cars have all 4 one touch now... At least have passenger front window one touch too to coordinate with driver's...
                              • Originally posted by ratedr View Post
                                Not sure where you got that from, my golf R has one touch on both front windows (it's a 3 door as they look better) and the polo has it on all four so I can't imagine them removing it on the next model up!
