Golf R Observations and Questions
  • Originally posted by Corey_R View Post
    How many songs do you have on it right now Fab_R?
    Hey Corey good question, its very full but i have all pod casts on there which are big files...
    • Originally posted by Fab_R View Post
      Can you watch video's from the ipod/iphone on the VW set up?
      2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
      2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
      • Originally posted by REXman View Post
        Hey REXman i will try it shortly and let you know.....standby....
        • Originally posted by HPSOV View Post
          Mine does exactly the same thing, which I have whinged about on here. It's as though the DSG program is the same one used in the GTI, which would work fine when you have peak torque starting from 1700rpm, but it doesn't come on till 2400rpm in the R.
          Interestingly the R (@ say 300Nm) makes more torque than a GTI (@ say 260Nm) at 1700rpm according to Oettinger power graphs (stock).
          Perception is an interesting confounding factor given the paise GTI's get for their responsiveness and to deriding R's get for their laggyness...the R engine is pulling harder (granted the car is heavier) lower in the rev range...suggesting it would be less laggy. The curve doesn't demonstrate the time between pressing the throttle and torque though???
          I say 'perception' 'cause relitively much more torque is happening at 2400 than 1700 in an R so it feels much better at 2400rpm and it is impossible to remember the feeling between cars well enough to avoid confusion.
          Strictly speaking, again using the Oettinger graph, GTI [I]peak[I] torque doesn't arrive until 5000rpm, where as the rather contrived R plateu arrives around 2400rpm. Granted at 1700 the majority of GTI torque is available.
          While I not yet a DSG convert (but open to the concept - sequential gear selection with no torque converter) so maybe I don't 'get it' but wouldn't you easily enough over-ride the fuel efficiency software programming by paddling down a gear or two while subtly accelerating?
            Hey Pepe I have a 2010 Golf R with RNS510 and use a 32GB card...no issues whatsoever. Works perfectly.....
            Hmmm....I wonder if the RCD510 would perform as quickly as the RNS510.....
            Maybe i'll play it safe and buy the 16GB one!
            | Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
            • Originally posted by Pepe View Post
              I was about to buy a 32GB one, but read that the RNS has issues when there are > 2000 songs on it, which you most certainly could fit on a 32GB card. Anyone know anymore details, like if it's been fixed?
              I have a 750GB USB hard drive sitting in the glovebox attached to the MDI interface on an RCD510. It's smart enough to power down when not in use.
              Music selection is only available be choosing a folder (not by artist/genre etc). However, playlists should work (I haven't set any up yet) and you can play all files in subdirectories (e.g. multiple albums from a single artist).
              It can be slow to display folders if there are a large number of them in the root directory.
              However, I've got plenty of space available for music / podcasts etc.
              2010 Golf R Black DSG 5Dr MDI Fiscon Plus
              • Hey Fab, I forgot to ask what class/transfer speed is your SDHC? I'm just wondering if it's worth it to pay through my nose for the Sandisk ULTRA Class 10 30mb/s one?
                • Originally posted by DDTW View Post
                  It won't make any difference to the playback, but it WILL make a difference to how long it takes you to copy the music on to the SDHC.
                  What I'd like to know though, is does the SDHC class make any difference to how long the RCD/RNS510 takes to initialise the SDHC after initial insertion?
                  • Originally posted by ethosguy View Post
                    Don't think that's right. Bigger turbo = more lag.
                      Has anyone tested out the time it takes to read a 16GB SDHC on the RCD510?
                      This youtube clip shows that it does take quite a while to read the SD Card.
                      YouTube - lahmes RCD510 im Golf R
                      True, however once read it takes one second to start after turning off system or ignition.
                      So, 30 secs to read 16gb (which is how many songs?), is acceptable to me.
                      How quickly does the RNS510 read it?
                      Sorry I should learn to read thru to end of thread before posting
                      Golf R MY 11.5 United Gray, 3 door, DSG, ACC, Free MDI, Bluetooth
                      Mods - APR Downpipe, VW Racing AI, HPFP, APR Tune Stage 2+- lovin it!
                      Touareg V8 TDI R-Line, White .Arrived 11 July.
                        Yeah that's my main concern too! I don't want to be waiting for the player to initialize each time I turn it on/off.
                        • I believe it only initializes once.
                          After that initial read it only takes a second to read even after turning off ignition.
                          Seems that way from the video.
                          • You're not going to flick though 16gb of tunes and surely you can narrow it down to 8 or 4gb that you might actually use? No point having the entire collection available if you're only likely to listen to an item once a year at best?
                            • I spent about $40 on a 8GB 30mbps SDHC card to copy music from my PC to my RNS510, since it was much quicker than DVDs. I rarely play music straight off the card these days, but when I did with it ful, it never took more than 10-15 seconds to get going.
                              I have more music than I need, but it all organised pretty well so I can either listen to everything randomly, or I can choose what sort of music I want, or narrow it even further.
                              I also made a silent 5 second mp3 file that I can play, which gives me just enough time to turn Shuffle/Random/Mix on, to listen to everything in the subfolders.
                              My only gripe with Mix/Shuffle mode is that when you turn the car off and then back on (after some time passes), it forgets what songs you've already heard.
                              Audi A3
                              • Originally posted by dave- View Post
                                The point is to not argue whether you'll listen to a song or not, it's to help people determine how best to do what they want.
                                Some people aren't as into music as others, which is why there are varying opinions on whether you need your entire collection, or whether you need the Dynaudio etc etc.
                                As others have said, it only initialises when you insert the SD card, not each time you turn it on/off. But if speed _does_ make a difference and you have a small capacity card combined with a large library, you probably don't want to have it take a few mins each time you put it in if you're constantly updating. The video we've seen shows that it takes only ~35 seconds with a 16GB SDHC card. But it doesn't disclose what speed rating the card is, or how many files are present and space is used.
