Nice hat!
MK3 Random Thread
Wasn't taking the piss, just looks posed.Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Originally Posted by JoeVR
I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
Thanks for that. Was hoping to get the Trans sump gasket locally just to get it done quicker but if coming from the states may take longerOriginally posted by stefcio007 View Postvagtex USA, $50 shipped. Came with the filter, rubber seal on the filter, gasket (with the four metal inserts).
Penrite says ATF FS Multi is the preferred fluid. What did you get?
I went for a fully synthetic nulon. Is called multi vehicle transmission fluid for the 096 box.
Ah right, I have different trans to you then.Originally posted by Speed View PostThanks for that. Was hoping to get the Trans sump gasket locally just to get it done quicker but if coming from the states may take longer
Shipping took only about a week, not very long IMO.Past - '95 VW Golf MK3 VR6
@Speed
Good news, did the whole thing today. Avoided jacking the car up and instead just took the front lip off. Everything went smoothly apart from getting the orange seal out of the transmission, that was slightly tricky but still easy.
It helps to have the wheel jack under the pan to hold it while you unscrew all the bolts and the same for when you have to put it back on, helps to keep it in position.
My pan had a big flat long magnet barely had any metal on it which is a good sign. The filter was the original filter, checked the date stamp! Company called Zeller made these filters for VW.
If you don't have a tube and funnel handy like me, SCA sells a kit for under $10, really needed to re-fill the transmission.
I tried doing the "kerma mod" but only got about two audible clicks, it's a hard spot to get to so I didn't spend too much time.
FYI, you need to reset the logic when you do everything.
One odd thing was most people say to NOT use dextron fluid, but the red filler cap has dextron printed on it...
Anyway, I might post a photo slideshow with what I did to help others.
Good luck!Past - '95 VW Golf MK3 VR6
Awesome!Originally posted by stefcio007 View Post@Speed
Good luck!
I bought a pump thingy to drain the oil from the filler tube. Cost 35.
Yeah I thought I had said dex3 to you earlier.
Whats this reset business and how does she drive now?Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Mate, there's a drain plug. That's how you drain the fluid, inside the drain plug is the fluid level plug. It's how you check you have the correct level. Sorry if you know this, but I can't really understand why you would buy a pump to get the fluid out.Originally posted by Speed View PostAwesome!
Whats this reset business and how does she drive now?Past - '95 VW Golf MK3 VR6
Just less mess when lowering the pan based on the write up i saw for a 096. Maybe overkill but it's another useful tool for the tool chest.
We have 7 cars so I'm sure it will get some some use.
I also have a dipstick to check the level.Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
If you are redoing the Dragon Green, it is meant to be a dark metallic green with a blue tint clearcoat which gives it a blue pearl effect. As the clear coat ages it loses the blue tint so you tend to lose the blue pearl effect, although the metallic green is still pretty good looking if you manage to keep it in good condition.Originally posted by browntown42 View PostWhat's the best way to paint the outside trim? it's cracking on the front bar and coming off on the rear bar. Should I just pay someone to do the roof, bonnet and trims all at once or is it a DIY job?
I would suggest that if you have the spare money to get it done professionally.1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
so, I did everything with regards to servicing the transmission. Checked the level 4 times, correct temp, everything, after changing the filter and gasket. The trans slips more than before though, I'm lost as to what has happened. I've reset the fuzzy logic of the controller and given it a bit of time to re-learn. I've found that it sometimes drops while turning. I had this happen before though but not very often. It sometimes has trouble engaging first. Once the car is rolling it changes gears like before.
I have a feeling that there is not enough fluid and it goes to one side while turning hence slipping, but if that were the case then why is the fluid correct when I check?
Anyone have an idea and what's happening?Past - '95 VW Golf MK3 VR6
Stefcio, Temp is measured once warmed up?Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Speed, yes, I measure the temp once warmed up and start checking the level once it's in the correct range. Maybe the fluid is too new and the car is just used to the old fluid?
Oddly, it performed well for a small incline today from a stop position, no slipping.
Maybe it just needs time.
Edit; vagcom is not throwing any error codes at all for trans.Last edited by stefcio007; 10-02-2016, 11:26 AM.Past - '95 VW Golf MK3 VR6
