Yeah I found with my BMC CDA that it mainly improved down low turbo response but other than that and "sweet intake noise" it's about it.
APR 2.0 TDI Carbon Fiber Cold Air Intake System
 Got mine installed in my MK6 GTD yesterday. I can definately hear more turbo spool when accelerating, and there is less turbo lag. The sound of accelerating for the first 10 mins or so is a bit noisy; but it seems to settle down after that.
 What do you mean?Originally posted by justin View PostThe sound of accelerating for the first 10 mins or so is a bit noisy; but it seems to settle down after that.2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
 TDI's have a choke cycle boys, injects extra fuel / EGR flap is pulling in extra EGR to aid warmup, mine is the same, super noisy till warmed up, and it's insane when doing a regen!2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
 I was also quite surprised how my exhaust after the mufflerectomy sounded in regen mode.Originally posted by Greg Roles View PostTDI's have a choke cycle boys, injects extra fuel / EGR flap is pulling in extra EGR to aid warmup, mine is the same, super noisy till warmed up, and it's insane when doing a regen!2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
 aaah!Originally posted by Greg Roles View PostTDI's have a choke cycle boys, injects extra fuel / EGR flap is pulling in extra EGR to aid warmup, mine is the same, super noisy till warmed up, and it's insane when doing a regen!
 The MK2 kinda does this. There is a hose bolted to the exhaust manifold that connects to the underside of the airbox to send warm air in.
 It was the first thing I deleted
 I'm convinced now of de-gridding my MAF.
 Not really - the tdi warm up cycle actually takes exhaust gasses back into the inlet of the engine to help warm up faster. Your mk2 just takes warm air from around the exhaust pipe to help warm up faster.Originally posted by benough View Postaaah!
 The MK2 kinda does this. There is a hose bolted to the exhaust manifold that connects to the underside of the airbox to send warm air in. .... its actually a good thing to keep on the old petrol cars because it gets the engine up to temp faster. Theres a flap in the bottom of the airbox that shuts the supply of warmed air off once the engine is warm, so there's no decrease in power or economy.
						'07 Touareg V6 TDI with air suspension .... its actually a good thing to keep on the old petrol cars because it gets the engine up to temp faster. Theres a flap in the bottom of the airbox that shuts the supply of warmed air off once the engine is warm, so there's no decrease in power or economy.
 '98 Mk3 Cabriolet 2.0 8V
 '99 A4 Quattro 1.8T
 Anyone know if the same part number CI100022 is appropriate for a '11 TDI Octavia vRS?2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
 I found this rather hardcore explanation:Originally posted by Greg Roles View PostTDI's have a choke cycle boys, injects extra fuel / EGR flap is pulling in extra EGR to aid warmup, mine is the same, super noisy till warmed up, and it's insane when doing a regen!
 VW and Audi TDI EGR system FAQ
 Right. Well I knew at least it was recycling hot air to warm it upOriginally posted by gldgti View PostNot really - the tdi warm up cycle actually takes exhaust gasses back into the inlet of the engine to help warm up faster. Your mk2 just takes warm air from around the exhaust pipe to help warm up faster. .... its actually a good thing to keep on the old petrol cars because it gets the engine up to temp faster. Theres a flap in the bottom of the airbox that shuts the supply of warmed air off once the engine is warm, so there's no decrease in power or economy. .... its actually a good thing to keep on the old petrol cars because it gets the engine up to temp faster. Theres a flap in the bottom of the airbox that shuts the supply of warmed air off once the engine is warm, so there's no decrease in power or economy.
 True but the MK2 warms up pretty quick and I always take it easy until the oil temp's up to 90.
 I always understood that heater pipe thing was more for the european winters.
 Also I had the oil cooler/warmer retrofitted to mine which aids warm up significantly.
 Are you running a different air intake or still stock?Originally posted by benough View PostDe-gridded my MAF today. Well, I cut it out
 It does feel a touch spritely under load but there's no extra power.
 Well worth the 10mins of effort 2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille 2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
