G-8VXWWTRHPN APR 2.0 TDI Carbon Fiber Cold Air Intake System - VWWatercooled Australia
  • #76
    Yeah I found with my BMC CDA that it mainly improved down low turbo response but other than that and "sweet intake noise" it's about it.
    • #77
      Got mine installed in my MK6 GTD yesterday. I can definately hear more turbo spool when accelerating, and there is less turbo lag. The sound of accelerating for the first 10 mins or so is a bit noisy; but it seems to settle down after that.
      • #78
        What do you mean?
        2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
        • #79
          Originally posted by poyta View Post
          What do you mean?
          Just sounds like I can hear the turbo fan spinning more than before, and the CAI sucking more air in.
          • #80
            TDI's have a choke cycle boys, injects extra fuel / EGR flap is pulling in extra EGR to aid warmup, mine is the same, super noisy till warmed up, and it's insane when doing a regen!
            • #81
              You should hear what a regen sounds like with a downpipe. Rattling 5" Civic muffler, anyone?
              TR 08 Golf GT TDI, Custom Code Phase 1, Milltek Exhaust, Whiteline RSB + ALK, APR Carbonio Intake
              • #82
                I was also quite surprised how my exhaust after the mufflerectomy sounded in regen mode.
                • #83
                  aaah!
                  The MK2 kinda does this. There is a hose bolted to the exhaust manifold that connects to the underside of the airbox to send warm air in.
                  It was the first thing I deleted
                  I'm convinced now of de-gridding my MAF.
                  • #84
                    I got one in my Caddy 1.6TDI. Sounds great!! Made it go a lot better too
                    Main Dub:
                    2010 Crafter Hanover Bus
                    1956 Type 1
                    2015 vRS wagon black on black
                    • #85
                      Originally posted by benough View Post
                      aaah!
                      Not really - the tdi warm up cycle actually takes exhaust gasses back into the inlet of the engine to help warm up faster. Your mk2 just takes warm air from around the exhaust pipe to help warm up faster. .... its actually a good thing to keep on the old petrol cars because it gets the engine up to temp faster. Theres a flap in the bottom of the airbox that shuts the supply of warmed air off once the engine is warm, so there's no decrease in power or economy.
                      '98 Mk3 Cabriolet 2.0 8V
                      '99 A4 Quattro 1.8T
                      • #86
                        Anyone know if the same part number CI100022 is appropriate for a '11 TDI Octavia vRS?
                        • #87
                          I found this rather hardcore explanation:
                          VW and Audi TDI EGR system FAQ
                          • #88
                            Right. Well I knew at least it was recycling hot air to warm it up
                            True but the MK2 warms up pretty quick and I always take it easy until the oil temp's up to 90.
                            I always understood that heater pipe thing was more for the european winters.
                            Also I had the oil cooler/warmer retrofitted to mine which aids warm up significantly.
                            • #89
                              De-gridded my MAF today. Well, I cut it out
                              It does feel a touch spritely under load but there's no extra power.
                              Well worth the 10mins of effort
                              • #90
                                Are you running a different air intake or still stock?
