My vote is none mate. You have no DPF, nothing to clog. Get the jizzum out!!
EGR should we all be more concerned
I will be keeoping you all posted as soon as I do one. The local dealer is doing them and say the 2L TDIs are a lot harder to do than the 1.9s.
AndrewPar 6 Golf GTI. Coilovers, BBS CH Wheels, APR'd
Originally posted by Buller_Scott View Postgtimk5 keep us posted!
im thinking of getting volkspower to clean out the intake manifold sometime.... but given that the turbo and manifold are one unit, i dont know what problems this will pose.VW: it aint just a car, its a way of life
For the record, I just ordered a new inner filter replacement for my Provent, at a rather pricey $59 plus GST from Sydney Filter Services, but as the last one has covered a year, it's not that bad I guess.
Also the water/ metho I had been injecting passively into the inlet has done little to remove the sludge, so now I have a bottle of Fuel Doctor injector cleaner in there, with some more metho. See what happens....2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
When the inlet tract in my T5 or Golf will need cleaning I will spray inside the inlet tract with the Inter-Ject Diesel Care & Cure Cleaner when the engine is hot and leave it standing overnight that should get most of the gunk off.Last edited by Transporter; 15-04-2009, 07:24 PM.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostWhen the inlet tract in my T5 or Golf will need cleaning I will spray inside the inlet tract with the Inter-Ject Diesel Care & Cure Cleaner when the engine is hot and leave it standing overnight that should get most of the gunk off.
sorry for my ignorance..
Originally posted by Buller_Scott View Posttransporter, do you mean into the intake manifold in that bit of pipe after the maf?
It would be better to remove intercooler and all the pipes for cleaning.
There is nothing wrong with a bit if preventative maintenance but don't seek the problems. On most engines it will take more than 160,000 km until it will
have any ill effect on the performance. The inlet manifold will always have some black oily residue in it (no reason to panic), it is normal unless it is a
brand new engine. I'm not cleaning mine, not before I see the fuel economy and power from engine changed because of the sludge in the inlet tract.
Just enjoy driving the car. Have a faith in VW, that they didn’t build the TDI to last only 3 years 100,000km. Car market is very competitive and it
would be suicidal if they did. But also consider that, if someone modifies the car or the engine than he changed the VW product and VW should not be blamed.
Modified engine needs modified maintenance and it will have the modified life span.Last edited by Transporter; 16-04-2009, 08:53 AM.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
I was thinking about spraying into EGR flap motor section after disconnecting fat pipe that coming up from intercooler, not sure though..2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
What I did. Just be aware your inlet runners point downhill into the head, and will fill with the solvent. Despite letting mine air for several hours, it started like mad as the diesel "ate" the volatile solvent, did a major but brief rev, which on a cold, no oil pressure engine, isn't the best idea. Hence the initial video showing a air limiter in the inlet, to control any run away revs. VERY important!2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Originally posted by HiTorque View PostWhere would that gunk go in the morning? I guess it will cool down and stay there..
It can be sprayed onto EGR flap and you don't have to wait several hours, but it works best when it has time to soak into.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by cogdoc View PostHence the initial video showing a air limiter in the inlet, to control any run away revs. VERY important!2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
Originally posted by cogdoc View PostWhat I did. Just be aware your inlet runners point downhill into the head, and will fill with the solvent. Despite letting mine air for several hours, it started like mad as the diesel "ate" the volatile solvent, did a major but brief rev, which on a cold, no oil pressure engine, isn't the best idea. Hence the initial video showing a air limiter in the inlet, to control any run away revs. VERY important!
Very bad for the engine I wouldn't do it on regular bases.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostIt depends what you spray in. The Interject Diesel Care & Cure doesn't evaporate so I don't see a problem that after few hours it would turn onto the solid. I use Interject products for 10 years and use it on many engines with a great results, I don’t see the gunk from TDI engine would be any different.
It can be sprayed onto EGR flap and you don't have to wait several hours, but it works best when it has time to soak into.2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
Originally posted by HiTorque View PostIs this one: http://www.interject.com.au/diagnostics/diagnostics.htm - Inter-Ject LB291/2F (403A) ?
Yes. Diesel Care & Cure is product code 420.
If you thinking of getting one, the smaller one ( Inter-Ject LB291/1F (401)) is ok for cleaning jobs and even diagnostics. Second tube on LB291/2F is for measuring fuel injectors flow.
I have bouth units.
Always have this one in the van.
Inter-Ject LB291/1F (401)Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
