Originally posted by cogdoc
View Post
EGR should we all be more concerned
Mate, all the mesh does is smooth the airflow over the MAF hot wire element after the 90 degree stock airbox outlet. IF anything, removal of the grid would allow a little extra air, and the car would, at worst, produce less soot! I'm not concerned and figure it won't affect EGR / sludge at all. Can't see how it would actually.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Originally posted by Transporter View PostIs the engine chipped or reflashed for more power than stock?2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
Originally posted by HiTorque View PostStock 100%, I got new EGR valve and flap motor, hate going through this again in 4 years time, and I don't know for sure if I picked up that shty diesel fuel from Caltex or this is what every mkV diesel owner should expect..
Originally posted by neil View PostHiTorque what was the engine doing for you to realize you had a problem with the EGR.
I would like mkV diesel owners to inspect their EGR parts and post their findings if its possible. If someone else has the same problem then we can discuss this further. According to the dealer (I don't want to name them here) they have 2-3 such cases a month, but this can be either correct figure or not...2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
Originally posted by greygolf8 View PostNot being a mechanic, is there an easy way to inpsect the EGR parts ie remove a hose, or is it numerous parts .... ?
1. You need special tools, otherwise after some time spent you will hate everything about VW, I still didn't cool down...
2. You will need to buy two O-rings from VW parts that go on EGR motor and EGR valve and re-new existing ones
3. If something goes wrong he would be able to put everything back together
4. It took me over three hours to get this done including cleaning, but it was too late for the damage, I could not get EGR valve working.2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
These russians had similar issue and as far as I could understand from photos they had to make parts of EGR valve from something else, interesting idea IMO:
http://volkswagen.msk.ru/forum/index...howtopic=822482005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
Interesting find, looks like they had to rebuild the diaphram for the valve. sadly it shows a fault in English on the first post as "EGR insufficient flow" so if we hobble the EGR flow, it's going to throw an error....2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
I found the file about NOx and DPF.
Here is the link.
Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by cogdoc View PostInteresting find, looks like they had to rebuild the diaphram for the valve. sadly it shows a fault in English on the first post as "EGR insufficient flow" so if we hobble the EGR flow, it's going to throw an error....2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
I wouldn't do that very often.
It would put more wear on the gearbox and the engine.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
