Discover media doesn't support DDP. Only bap. So you need to either upgrade to white/colour cluster or use a fislink to translate between bap and DDP.
Discover Media retrofit
I wanted to find out if you know how to change the logo of the car when you put it into reverse?
I have a Passat estate, but when i put the car into reverse it shows an Amarok (donor car). I know it can be done through VCDS and I have got connection via 5F module manualy as it doesn’t appear on gateway list. I don't know which byte and value use to make it display estate/kombi picture. That's actually minimum I would like to achieve... If anyone can help me get it fully coded that would be awesome.
My radio model is 5C0035680E
please see vcds scans attached
full vcds log:
detailed 5F log:Code:Monday,01,July,2019,22:13:58:01249 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 15.7.1.0 Data version: 20150904 www.Ross-Tech.com VIN: WVWZZZ3CZEE063712 License Plate: Mileage: 90050km-55954mi Repair Order: Chassis Type: 3C (7N0) Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4C 4F 52 53 56 61 62 72 77 VIN: WVWZZZ3CZEE067312 Mileage: 90050km-55954miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Not registered 0001 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 4C-Tire Pressure II -- Status: Not registered 0001 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Not registered 0001 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb Part No SW: 03L 906 018 PR HW: 03L 907 309 AE Component: R4 2.0l TDI H28 9979 Revision: 41H28--- Serial number: 00000000000000 Coding: 00190012042501080000 Shop #: WSC 34555 001 1048576 ASAM Dataset: EV_ECM20TDI01103L906018PR 003007 ROD: EV_ECM20TDI01103L906018PR.rod VCID: 091E516FA83DA3760A-805C No fault code found. Address 10: Park/Steer Assist (J446) Labels: 3AE-919-475.clb Part No SW: 3AE 919 475 C HW: 7N0 919 475 Component: PARKHILFE 8K H06 0018 Revision: -------- Serial number: 28231333400596 Coding: 108002 Shop #: WSC 99999 1023 2097151 ASAM Dataset: EV_EPHVA18VW47X0000 001006 ROD: EV_EPHVA18VW4280000.rod VCID: 3F8A8FB7A6795DC664-806A No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb Part No SW: 3C9 953 501 DA HW: 5K0 953 569 BA Component: LENKS.MODUL 016 0140 Revision: FF010042 Serial number: 20131202200571 Coding: 1182250000 Shop #: WSC 00015 115 00001 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 6BD20BE78281116698-803E Multi Function Steering Wheel Control Module: Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Component: E221__MFL-TK6 H07 0022 Coding: E20000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb Part No SW: 3AA 920 970 N HW: 3AA 920 970 N Component: KOMBI H04 0811 Serial number: 00000000000000 Coding: 461F01 Shop #: WSC 05314 115 00001 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721 ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod VCID: 3E74F2B3A17354CE6F-806A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM Component: J533 Gateway H55 1642 Revision: H55 Serial number: 161013F2000357 Coding: 462007 Shop #: WSC 05314 123 00001 VCID: 7BF23BA7FAE181E608-802E 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 90058 km Time Indication: 0 Date: 2019.07.01 Time: 22:06:37 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3AA 959 433 B HW: 3AA 959 433 B Component: IMMO 043 0407 Revision: 00043000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 3878E4AB4B576AFEA5-806C Subsystem 1 - Part No: 3C0 905 861 J Component: ELV 029 0380 3C0905861J ELV 029 0380 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K0 909 144 R Component: EPS_ZFLS Kl. 195 3501 Revision: 00H22000 Shop #: WSC 02069 000 90108 VCID: 397EE1AF705D73F65A-806C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3AA 959 433 B HW: 3AA 959 433 B Component: KSG PQ47 ELV 043 0645 Revision: 00043000 Serial number: VWZCZ000000000 Coding: 0191020052830E76340494157C085FCE105C04 Shop #: WSC 05311 000 00001 VCID: 3878E4AB4B576AFEA5-806C Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 Subsystem 2 - Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Subsystem 3 - Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb Part No SW: 7N0 907 534 HW: 7N0 907 530 AM Component: Batt.regelung H55 1642 Serial number: 161013F2000357 Coding: 030F1859 Shop #: WSC 05314 123 00001 VCID: 71EE198FA8ADFBB6A2-8024 Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A Component: J367-BDM H07 0180 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End-------------------------(Elapsed Time: 03:16)--------------------------
current coding attachedCode:Monday,01,July,2019,22:08:46:01249 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 15.7.1.0 Data version: 20150904 www.Ross-Tech.com VIN: WVWZZZ3CZEE063712 License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 5F: Information Electr. Labels: None Control Module Part Number: 5C0 035 680 E HW: 5C0 035 680 E Component and/or Version: MU-S-ND-ER H31 0359 Software Coding: 06180701BE00000011111101008808001F0100D4002001004F Work Shop Code: WSC 02739 790 50316 ASAM Dataset: EV_MUStd4CTSAT 001022 (VW46) ROD: EV_MUStd4CTSAT_VW26.rod VCID: 234223C72AD1192660-8076 2 Faults Found: 6714 - Databus U1121 00 [009] - Missing Message Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 54 Mileage: 90058 km Date: 2019.07.01 Time: 22:06:40 1637 - Interface for External Media U11B8 00 [009] - No Communications Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 54 Mileage: 90058 km Date: 2019.07.01 Time: 22:06:36
Yes, the first 3 bytes of 5f coding control the vehicle image.
Update your vcds to the current release and it will be in the drop down for coding.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Hello colleagues
I am new to the forum and I live in poland
I installed my batch dicsover media 2 in my passat and everything works beautifully. Recently I connected the RVC High camera with the modul 7n0907441B. The camera works but I have a camera calibration error - I did not calibrate it because I do not know how to do it.
I have a calibration mat, but I do not know how to calibrate.
Can someone from my friends tell me how to do it?
I have vcd and vac can pro.
Thank you for your help.
You need to apply a Tiguan parameter set then use ODIS S to run the calibration routine, using Tiguan 2016 as the vehicle project.
The board needs to be at around 1600mm from rear axle but enter 1400mm as measurement into ODIS.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Originally posted by kamold View PostYou need to apply a Tiguan parameter set then use ODIS S to run the calibration routine, using Tiguan 2016 as the vehicle project.
I must first settle vas 5054a and odis software because I do not have it
I did as I wrote and I typed 1400 of the rest of the parameters I left at zero and I do not calibrate. Can you help me what toOriginally posted by kamold View PostYou need to apply a Tiguan parameter set then use ODIS S to run the calibration routine, using Tiguan 2016 as the vehicle project.
The other parameters you need to enter actual correct data.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
You need to make the measurements.
Height of camera from ground, height of wheel arch, height of calibration board from ground.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Change the language in ODIS2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Google translate is your friend2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
