Originally posted by Tristanmin
View Post
Sent from my HTC 10 using Tapatalk
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.8.0.1 HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72
VIN: WVWZZZ1KZDW002641 Mileage: 43930km-27296miles
10-Park/Steer Assist -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 JK HW: 03F 907 309 S
Component: SIMOS10.13AH10 2682
Revision: --H10--- Serial number: 00000000000000
Coding: 002500B6232401080000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM12TFS02103F906070JK 004005
ROD: EV_ECM12TFS021.rod
VCID: 74B2D4271E3FC6574F2-8020
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 060 D HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3656
Revision: 00043014 Serial number: CU501205055322
Coding: 0000020
Shop #: WSC 73360 981 89128
VCID: 2B000F5B8F01D9AFDE8-807E
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 133B400D212200FCC81102E8841A0090310000
VCID: 7DA4F1032DF5871F30C-8028
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 BG HW: 7N0 907 426 BG
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010004003
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 7AAEFA1F3C5BB02715E-802E
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 J HW: 1K0 937 084 J
Component: BCM PQ35 B 111 0709
Revision: AB111709
Coding: 46180A38E8251AC0408800C0340000244F510288436D8960648087200041
VCID: 3534292355459F5FB8C-8060
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 14051 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 160512 05 54 0403
Coding: 0F30AD
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 56D 919 475 A HW: 56D 919 475
Component: PARKHILFE 8K H02 0006
Revision: -------- Serial number: 35811401500962
Coding: 300101
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_EPHVA18VW4110000 001007
ROD: EV_EPHVA18VW4110000.rod
VCID: 3330173B5BB1816F968-8066
1 Fault Found:
12658720 - Databus
U1121 00 [009] - Missing Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 168
Mileage: 43938 km
Date: 2017.09.24
Time: 11:43:39
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 D HW: 5C0 959 655 D
Component: AirbagVW10G 013 0613
Serial number: 003G7RA1KCJT
Coding: 00004431
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME1C215166ZZZR
Crash sensor for side airbag: front passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME6F085566ZZZ2
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME782E1142ZZZU
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME6405114CZZZP
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AJ HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: WHRPIÄiÄHHHHS
Coding: 5880100000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 78AAE0170257A23763A-802C
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5K0 920 873 HW: 5K0 920 873
Component: KOMBI H05 0705
Coding: 570B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
VCID: 6D84C1437D15179F80C-8038
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 26031400F13662
Coding: 350003
VCID: 76B6EE2F08C3D447716-8022
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 168
Mileage: 43938 km
Time Indication: 0
Date: 2017.09.24
Time: 11:43:38
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0705
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8ECA5F4CFB00A7E5E-803E
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 5K0 959 701 J HW: 5K0 959 701 J
Component: Tuer-SG 009 2106
Coding: 0135862
Shop #: WSC 14898 001 1048576
VCID: 392C2513755D7B3F5C4-806C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 68 3305
Revision: 00H22000
VCID: 3728232B43496D4FAA0-8062
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Component: Tuer-SG 009 2120
Coding: 0136118
VCID: 3330173B5731816F968-8066
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AH
Component: Batt.regelung H50 1634
Coding: F300185A
VCID: 71BCDD3361ADF37FA44-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000008900316113
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0131216
Shop #: WSC 01357 011 1012552
VCID: 3534292359459F5FB8C-8060
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0131216
VCID: 36362E2F44439447B16-8062
End----(Elapsed Time: 01:03, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
