Originally posted by moda
View Post
DNS series head unit (new generation dual core RNS-510 alternative)
Yea you flashed the wrong version.Originally posted by Bassss View PostPhoto of my information
You have the 'A' type DNS, which is ONLY compatible with the NEW firmware with the NEW canbus module. What you tried to flash is only compatible with the OLD (non-A) DNS with the OLD canbus module.
Chances are you've bricked your unit. Get in contact with Audiosources.MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
((((((((((( I am very upset. The Chinese are now on holidays and do not answer for my questions. Have you my version of firmware?
Originally posted by Bassss View Post((((((((((( I am very upset. The Chinese are now on holidays and do not answer for my questions. Have you my version of firmware?
Is from October 2014.
Chances are you won't be able to recover your unit, though.MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
The only files that will be different are MCU, MPU and CAN. Difference will be very small, only in file size and date. All the rest will be the same.Originally posted by Bassss View PostWith yours new files all the same ((((((((((((((((((((((((((MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
Yep, because you've bricked your unitOriginally posted by Bassss View Posti mean that copied your files and it is still not working
Not much you can do yourself, unfortunately. Audiosources may be able to provide you with a recovery image, but i'm not sure it would work in your situation. Chances are you'll have to send it back to Audiosources. Send them an email anyway, asking for their help.MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
Does anyone play CD's in there units?
I have had troubles with mine and wondering if anyone else has.
Also, time on mine keeps reverting back to 2008 01 01 like the battery has been removed.
Anyone else had this problem?MKV Sportsline Soot Belcher
MKV Jetta FSI DSG
I play music via SD also but when I buy a new CD I listen to it before putting it on SD.
I bought a new CD on the way home from work today and I thought I had a CD already in the unit.
So I tried to eject it and nothing happened, then I changed it to DISC and it said NO DISC.
Tried to put the new CD in and it wouldn't go in.
I drove off and after about 2 minutes of driving I changed it to disc and low and behold it started playing the disc that it previously said wasn't in there.
As for setting the time in the Sat Nav area, I can't even find where to do that.
I have tried adjusting the time in Sygic since I first installed it with no luck.
My sat nav time is an hour behind even thought the time zone is correct and daylight savings time is on.MKV Sportsline Soot Belcher
MKV Jetta FSI DSG
