Originally posted by lucas__
View Post
DNS series head unit (new generation dual core RNS-510 alternative)
MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
Originally posted by profrat View PostIs PM on this Forum the only way to contact this seller? It seems like a very restricted, unreliable way to do business? I sent a PM a week ago and no answer.MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
Hi Hope you all had a Merry Christmas.
Very early this year I made enquiries about purchasing this unit. I was informed that it would not fit a VW Crafter dash, so I sadly did not proceed with my order. I instead searched out a unit suitable for the Crafter and had it within a few weeks and fitted the same day. Now almost a year old absolutely no problems with it. I am so sorry I couldn't have joined the people patiently waiting for this unit which never seems to improve.
New canbus installed. Hardest part is desolder and removal of old board.
Just unscrew 3 screws (1 on the back, 2 on each side) of bottom plate to access under side of motherboard.
Desolder old board.
Clean pins
Solder on new board as shown in pic by Sandy.
Reassemble.
I had the non A firmware which updated fine.
Seems all good.
Note . I did have to do soft reset after firmware restart as SD card didn't load.
Mfd works but only has basic info like track number or radio station numbers.
So.. Anyone with a mk5 installed the new unit?? I just received mine and opened it up, it looks deeper(especially the screen) and am a little worried it may protrude from the dash, not too keen on that...Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
-MK1 Golf The re-spray/re-build
In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
A pattern seems to be forming...
I installed mine.
Yes the screen is deeper but the frame lines up with the trim.
I had trouble getting the main wire to clamp in (thought I was going to break the plug).
Don't really like the chrome trim on it, looks cheap and will probably start to peel.
Bluetooth isn't as good as the dns-610 it replaced but the sound is better and a couple of
features seem to be back that had disappeared with some of the firmware updates.
Just waiting on Sandy to give me an activation code for Sygic so I can try it out.MKV Sportsline Soot Belcher
MKV Jetta FSI DSG
Sweet, that is all I wanted to know as I'm going away and won't be able to install till the 15th Jan. Wouldn't want it to then not fit.... HahaMine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
Originally posted by Fdandy View PostNew canbus installed. Hardest part is desolder and removal of old board.
Desolder old board.
Clean pins
Reassemble.
Seems all good.
Also, the new board is much smaller than the original board, interestingly.MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
Yeah it was quite tough. I used both wick and a desolder tool which seemed to help more than the wick to grab the solder from the holes. After I got as much solder off all pins I started from one side and slowly pried up each pin one at a time (a side at a time).
I used gentle force to pry up.
This is the type of tool I used as well as the wire.
Plastic Desolder Tool- Jaycar Electronics
I'm sure there a better ways as I only have simple soldering experience.
Once the board us off, the new chip fits easily and easy to solder.
Originally posted by Fdandy View PostYeah it was quite tough. I used both wick and a desolder tool which seemed to help more than the wick to grab the solder from the holes. After I got as much solder off all pins I started from one side and slowly pried up each pin one at a time (a side at a time).
Once the board us off, the new chip fits easily and easy to solder.Yea, I used a solder sucker first, and then solder wick to get the remainder. Didn't think to heat each pin individually and gently pry up to get them lose. Used a trim removal tool to get some leverage, and just got one side, the second side shouldn't be too bad. Resoldering is the easy part haha.
Will let ya'll know how it goes.MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
Success, all working
Also, @Sandy, Sygic upload?Last edited by moda; 04-01-2015, 02:39 PM.MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
