This thread is about the new generation dual core DNS series units. It is an upgrade of the previous ANS series units. The ANS series thread is below:
A pre-production batch was sent out to approximately 15 customers who opted in. Several issues have been identified which are to be fixed in the final production unit. A group buy is currently running and for now, please find all details on the unit here:
This thread will be filled with detailed product information after the group buy closes. At the moment the purpose is to direct queries and feedback here as it would be more appropriate than the Parts for Sale section, and also because I'm unable to add much more to the OP in the group buy thread due to character limit.
Firmware and useful links will be placed in this and the following reserved posts - I will expand them as necessary.
Current Status
The bugs / issues listed in the bugtracker spreadsheet below are now rather out of date. The main issue awaiting resolution at the moment is the SD / navigation clash issue where songs may stutter or refuse to change to the next track, when navigation is running in the foreground. The current status is that if the issue is not fixed, or has a set fix date by the beginning of May, I will switch navigation software to Sygic, which does not have this clash issue, and wrap up the group buy.
Bug tracker / tips / useful info
The below is a spreadsheet compiled by the customers who received the pre-production units. Note because it is a public document there are issues in there that may already be resolved in new firmware versions, or issues that may duplicate / be related to other issues. Huge thanks to all that contributed to this spreadsheet, especially moda who cleaned it up and gathered useful information.
Note down the bottom there are 4 worksheets. The last worksheet can be ignored. The first worksheet is the bug tracker, second worksheet is the firmware update procedure, and the third worksheet is a compilation of tips and tricks.
Latest firmware - NOTE PLEASE FLASH MCU FIRST!!!
Latest Firmware (BSP + MPU + MCU) June 2014 Read new instructions in spreadsheet
Latest Firmware (BSP + MPU + MCU) May 2014
February firmware with TEST MCU for DNS-810 ONLY:
Update instructions per spreadsheet above, second worksheet.
Changed features since announcement
Mirroring module
Previously it was announced by Audiosources that two-way Android mirroring (i.e. with controls via the unit) was going to be a feature of the unit. It turned out that they created an optional module for this feature, but instead of two-way communication it is only one way (i.e. display only, still need phone to control). The flip side is that this module is also compatible with iPhones. This module is $55, with $5 extra for a Samsung adapter.
To those in the group buy who expected mirroring to be a feature rather than an add-on module at additional cost, the module is offered at $45 instead.
Screen
Previously the screen was announced to be capacitive. However this has now been changed back to resistive due to driver compatibility issues with WinCE. The resistive screen is of good quality (the factory RNS-510 is also resistive).
Delayed features
The features / modules previously announced below have been delayed and will come in the future. Software features will simply be applied by a future firmware update.
Full three-line MFD display (currently only one line)
MFD navigation display
ID3 tag-based music library (currently folder-based, but is capable of shuffling across folders)
better iPhone integration (currently basic and missing memory of song / position on shutdown)
OBD2 module
trip recorder
DAB+ module
White screen / monsun.exe error
Some who received the pre-production unit have come across a white screen error. Others come across monsun.exe error while playing SD. It is unclear if the two are related at the moment, but the white-screen error has been tracked to a faulty resistor which will be replaced in the final production unit. Those with the pre-production unit experiencing issues will be able to exchange for a final production unit on release. International customers will need to send the unit back to Audiosources and local Australian customers will send it back to me.
monsun.exe error is under investigation and should either be related to the resistor fault or software memory leak. In the latter scenario a firmware update would fix the issue. However the technicians have not been able to replicate this yet, so anyone who is able to replicate it please let me know and describe in as much detail as possible how the issue occurs, including if GPS is running in the background, if route guidance is on (i.e. during a trip), and what song / file type is being played, how big the file is, how long the unit has been on for etc.
Current Status
Mirroring module
Screen
Delayed features
OBD2 module
trip recorder
DAB+ module
