DNS series head unit (new generation dual core RNS-510 alternative)
  • Originally posted by Bassss View Post
    Thanks a lot! It is works on my DNS830 fine!
    I want to try edit language files. Is it real? It have bad russification.
    And I have no climate visualisation after MCU update. It shows only then i turn it off.
    And I have newer can software ver 2.34 but it is not turn off device automatically and now I use 2.27
    Editing system files is just going to be trouble mate, don't bother.
    Originally posted by subieboy View Post
    Quick update.
    Been running Sygic for some time now with very little issue - that being the zoom function
    Have noticed that at night the unit as 3 setting for brightness - bright, bright and screen off... Is there a setting hidden somewhere to adjust that?
    The unit is working fine otherwise
    I don't believe we ever had any better settings for brightness. It's never been an issue for me, though.
    Originally posted by Goobz View Post
    Has anyone else had any battery drain issues? Since installing the new can chip I get a flat battery at least every other day. If not I have to start the car twice for the unit to power on. I think the silent boot feature is borked and not shutting off/booting up when it should. Its at the point now where I carry a battery pack around with me just in case.
    Originally posted by Fdandy View Post
    Yeah. I reckon I'm having a battery drain issue. If I don't use my car for 3 or 4 days it drains the battery and I need to jump start. I've installed a new battery to help but I'm sure the unit is affecting it. Sometimes unit doesn't load past logo screen since last firmware and I soft boot it to get it going. Think we need new firmware.
    No battery drain issues at all for me on my unit (Old CPU/New CAN) with:
    BSP: MS9.H.32.1119
    MCU: DNS810.1219
    MPU: DNS810.02Feb15.32.VW.V45.C
    CAN: VW_V02.28
    Even when I didn't drive the car for a week or so, started straight up, even on a cold morning (though I do have a brand new battery, with a much bigger capacity than stock).
    On the firmware side, no real show stopper bugs, just little things that would be nice to clean up, but otherwise running fine. MFD functionality still isn't great, but eh.
    Originally posted by craze View Post
    I had the same problem with boot logo freezing with can VW_V02.33.
    I installed the older version VW_V02.27 and the problem was solved.
    Can i ask where did you people get Sygic from?I have searched the web and have found nothing to be working.
    See my links here for a trial version Sygic 8.5 with 2013.09 maps: http://www.vwwatercooled.com/forums/...ml#post1076017
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
    • Battery drain issues are related to old Can Gateway in your car.
      It is not a DNS problem as the same would happed even if you tried to fit a rather new verison of RNS510 or RCD510.
      Also, your CAN Gateway is not faulty, just incompatible with newer features/modules on the CAN bus.
      You probably have a prior 2007-2008 model.
      My 2010 Passat (build late on October 2009) has the CAN Gateway below and works fine.
      This is the CAN Gateway part of a VCDS scan of my car.
      Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
      Part No SW: 3C0 907 530 L HW: 3C0 907 951
      Component: J533__Gateway H13 0152
      Revision: H13 Serial number: 3300P09A14002F
      Coding: F9A07F46000202001002
      Shop #: WSC 05314 123 12345
      VCID: 2A5113E68547F64EEA7-807F
      No fault code found.
      A newer version 907 530 can be found on ebay for about 45€.
      You can find plenty of information about it but in case you plan to replace it yourself you will need to first get the current coding using VCDS in order to perform the same coding in the "new" CAN GW.
      I don't know the exact version needed for your cars but you have to start by knowing what exactly is currently installed.
      • I totally agree with kakourgos.
        • Hey moda thanks for the link but it does not contain the Greek map.
          • Originally posted by craze View Post
            I'm pretty sure we've talked about this before, thought we already discovered that those Sygic packs didn't have greek maps? Anyways. You have the program, now you can probably just go to Sygic and *buy* Greek maps... or whatever.
            • Unfortunately they are not for sale anymore!Sygic stopped support...
              • Hey,
                So I just bought an 07 Golf GTI MY07, and I'm pretty sure I'd like to replace the RCD500 on it with a DNS-610, or similar - it appears to be the latest version of the RNS-510 alternatives.
                I have a couple of questions regarding these things:
                1. Do I need an additional bluetooth module in order to get it linked up to the steering wheel etc? I'd like full functionality (bluetooth audio through all speakers, etc), so it seems like I might, but I was wondering if there are any units like the DNS-610 that just do it out of the box since they're already connected to the CAN bus anyway. It seems Audiosources does android head units now - maybe they have BT built in?
                2. In relation to #1, I have checked under the drivers and passengers side seats, and there is what appears to be a computer of some sort under the passenger seat and nothing under the drivers side seat. I take this to mean there is no BT at all...so I have no idea where to start there. There is a phone button on the steering wheel, however.
                3. I'm fairly sure I'll need to upgrade the CAN bus to avoid battery drain issues given it's an MY07 - I can probably do this myself, right?
                4. Is the DNS-610 currently free of issues? I really don't want to be messing around with it at all, so if it's going to be problematic I'd probably just stick with an RNS-510. That said, it does look *much* better in terms of performance etc.
                Any help is appreciated!
                • I have a 2007 EOS which is very similar to the 2007 GTI. I had the MFD2 installed from new but I have now installed the DNS-810 installed with RVC in the VW logo. The blue tooth is in the DNS-810. All the buttons on the wheel work however the MFD display does not show everything - but more than enough. The DNS-810 was an extremely easy install and I did not have to change the CANBUS. I do not have any battery drain issues as long as I lock the car when not in use. All the speakers work and the Sat Nav is light years ahead of my old MFD2.
                  The RVC was not so easy an install - probably due to EOS wiring requirements. The Golf should be much easier.
                  It fits into the dash easily.
                  • Thanks for that - I actually just bought one of these. It has android, and BT is built in so it should be pretty cool. The support guy Tommy was really responsive, and from my googling he posts on vwvortex quite a lot, and updates the software regularly. I think that's worth the bit extra IMO, and they're american so you don't need to do a group buy from Alibaba.
                    • Looks good. I had not seen those before. Some nice features too
                      • Hello everyone! I need some help ) I bought DNS-620 for my Skoda Octavia A5fl 2010. And I have some troubles with it.
                        1) It not turn on automatically when I start my car. I need to start car twise or push hardware reset buton.
                        2)bluetooth microphone is so quiet (people not hear me)
                        3)on my mfd I see only one line and it looks like "track 1" "track12"...
                        4)song name not scroll on display and some titles of songs looks like china letters...
                        There is scan of my gateway:
                        Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
                        Part No SW: 7N0 907 530 HW: 1K0 907 951
                        Component: J533 Gateway H27 5603
                        Revision: H27 Serial number: 050810F1000171
                        Coding: E9A07F0600020200001302
                        Shop #: WSC 01530 935 00200
                        VCID: EDD1AF36F4317376CF5-80B8
                        There some pictures about fw versions:
                        Help me please... It makes me crazy every trip push hard reset
                        • Hi all
                          I'm interested in buying this device for my '07 passat. Can you say about sound quality of this sound system, and will it work perfectly with my car? I had installed can-bus gateway from '12 passat B7 and climate electronic module from B7 too, will visualization work with my car? And can anyone tell me about mirror link box? I want to buy it too.
                          thanks a lot!
                          • Sound quality is the same with original bolero,or better ) I have no problems with sound quality.
                            • To all the new people coming into this thread, to be completely, brutally honest, the DNS series of headunits is still in a state of half baked, unfinished 'meh'.
                              While 95% of it's functionality is fine, and works, there are still a few bugs here and there (no show stoppers), the amount of time it took to get to this point is ridiculous, and AS still haven't delivered on 2/3rds of what they promised originally. Everything works as it should, for me (FM radio, iPod connectivity, GPS navigation etc etc), is fairly fast for a WinCE unit, and OEM integration is pretty good (though MFD functionality is ****). I don't think it was worth the $700 or whatever that I paid for it way back when... if it was more like $400-500, that is a much better price and would have no issues recommending it. I still have and use mine, but I wouldn't really recommend it to others for how much I paid, though I don't think i'll be replacing it any time soon (until Android Auto/Apple Carplay units start coming out that are actually decent). Can't imagine there are going to be many more headunits running WinCE going into the future, most stuff will probably end up being Android.
                              Also, for what it's worth I much prefer Sygic to iGo, in my mind Sygic is much slicker and has better UIX and navigation. The difficulty is that Sygic aren't supporting it any more (there are no currently supported WinCE navigation applications on the market), so maps might be updated into the future. iGo is just easier to get access to (free) maps and is modder friendly, which is why it's more popular. From a UIX and navigation standpoint, personally, I think it's a piece of crap.
                              Originally posted by GeorgeK View Post
                              Hey,
                              1) No. All aftermarket headunits have their own inbuilt BT modules. AFAIK the only one that allows you to use the OEM VW one is Zenec.
                              3) Yes.
                              4) No.
                              1) From memory I think that was a firmware bug (??).
                              2) BT microphones on the vast majority of headunits are **** anyways, DNS is no exception.
                              3) MFD functionality on the DNS is ****. Wouldn't expect it to get fixed.
                              4) Don't expect that to get fixed either.
                              Originally posted by pervakovcrea View Post
                              Hi all
                              thanks a lot!
                              The sound quality of the DNS will be on par with the vast majority of other headunits, to be honest. Mirrorlink box is as far as i'm aware mostly non-existent.
                              • So where I can get firmware to fix my "power on" problem?
