This is a sticky topic.
  • Originally posted by shane_in_oz View Post
    did the software update seems all good. I tried loading the ver 6 au maps hat I have but it is not being recognized by the head unit. does it need to be the original disc as I never got one with the car.
    thanks
    You cannot load the same version map over the top of itself Have a look for a V5 and load that then update to what you had Other option is to spend $55 and buy V7.
    Please don't ask on here for a copy.
    • All working perfect now thank the info hillbilly
      2016 Scirocco R - 2015 Polo GTi
      • It looks like there are a few newer versions of firmware that in OP. However h/w compatibility is questionable. For instance, the 5269 and other 52xx have a comment "All D and later versions", my RNS510 is the 1T0035680C, so it would appear I'm right out of luck.
        But wait! There's more. This firmware list mentions my version as being supported with a "modified version" of 5269... well, that is cryptic enough for me to avoid and let someone else experiment. Does anyone know what this is about?... original thread in german (I speak german btw). I'll keep digging.
        UPDATE: Looks like this modified firmware is the way to go.
        http://gpsunderground.com/forum/volkswagen-seat-skoda/20308-all-available-firmware-rns510-45.html
        .:R36 MY10.5::Wagon::Biscay Blue::Adaptive Dampers::Sunroof::Wheels:.
        • Originally posted by Felixrising View Post
          Put 4120 in and be happy Mine is a C and it works as well as anything VW can There isnt really any advantage going to anything else.
          Euro versions are different due to the size of partition required for the larger maps.
          Also some of the higher numbered versions are for units with DAB boards and you can stuff an older unit if you load it, be warned
          • Yes, I installed 4120 last night, no issues - despite many reports of needing to recode when flashing 4120 on other threads... The newer 52xx stuff is reportedly faster...
            • Voice Control (requires microphone – see Volkswagen RNS 510 Microphone Connection for voice control)
            • NEW DAB+ Support (from 5xxx)
            • NEW DAB Support (from 4xxx)
            • NEW Radio Text (from 4xxx)
            • NEW Faster navigation and user interface
            • NEW Automatic illumination control
            • NEW Enhanced destination input
            • NEW hold down the setup button for 30 seconds and get the following menus: FM, AM and the new VERSION INFO (map version and type, hw and sw versions)
            • NEW Compass
            • NEW POI- see Volkswagen RNS 510 Maps POI – New Features with firmware 3xxx
            • NEW Languages – Arabic, Russian, Turkish and Polish
            • Speed Limit Display
            • Stability Improvements
            • Faster Startup (from 2720 onwards)
            • Display OPS and RVC at the same time
            • SDHC 32 GB Support (HW04 and above)
            • Display Off on extras tab
            • Climatronic control if approriate climatronic fitted
            • Clock display if RNS 510 swtiched off
            • Excluded roads (under route options)
            • GPS coordinates entry
            • Additional adjustments for video
            • Larger RVC screen with transparent menus at the side
            For the moment, I'll stick with 4120 as per your suggestion... thanks.
            5238 modified is here: All available Firmware for RNS510 - Page 45
              As you see from what you have posted it supports DAB and DAB+. Also that forum page 45 link is a European one and the partitions on the HDD for modified firmware is totally different
              If you load it in an unit without a DAB board you run a very good chance of bricking it.
              Thats why most of us dont use it.
              Have never had to recode ever in several incremental upgrades
              Your choice however.
              • Yes, the model number must match... Mine is the 1T0035680D, 680 is the Australia/NZ version, so I wouldn't touch it unless the version matches the description. There are a few people who asked the question regarding this specific version and some answers saying, you can do it anyway... I'll PM them to ask how they fared.
                Last edited by Felixrising; 27-09-2014, 07:09 PM. Reason: updated model - mine is a D not a C
                • I have been testing 5238 for some time.
                  No enhancements or changes worth mentioning.
                  If you simply MUST have later firmware on your unit because you like to fistpump every time you upgrade and don't brick you unit, PM and I will send you a link with firmware modified for Aus.
                  Otherwise stick with 4120 as you won't notice anything. This is why I haven't made it available. Risk for no reward.
                  • Originally posted by kamold View Post
                    Does it seem more responsive?
                    Any idea what the 'Automatic illumination control' is, compass worth mentioning?
                    MK6 CS GTI
                    • No. These features are from earlier updates.
                      The list is like a complete changelog since initial release, not the current version.
                      Compass has been in there since 2600 firmware, auto dimming perhaps even earlier.
                      • I was just poking around and noticed the HWDAB field populated... 255 looks like 11111111 in binary, which I guess could mean nothing present or something present... No idea... What does yours show?
                        Also, I was copying some music from a music folder on sdcard to hdd, but I noticed after copying that it seems to have eliminated the music folder and moved the album folders to the root of the hdd... Is this typical or did I miss something along the way... How else do you do a bulk import?
                        Also, I saw somewhere that rev D onwards (C10/C11/C12) supports bigger 2TB SDXC cards... but no support in software it would seem.. FAT64/exFAT seems to be missing I guess.
                          If you read through the thread (Its a good idea) I think in one of Kamolds posts he said the 255 means IT DOESNT HAVE DAB
                          From GTI Forum
                          The version tested to work here in Australia is the 1T0035686C (1T0 035 686 C) with a Hardware Level of HW:09 and running software level 5238. This unit is a stock RNS 510 with LED screen, 40GB hard drive and is the latest available model from Volkswagen.
                          Only the above has DAB C and a D most definitely DONT. Mine is a C and when you put the 4120 in it changes to appear as a D but in fact is still a C Its all in the thread if you care to read it
                          I have a 40g HDD and a 32g SD card and I just play the music off that because it took 2 hours for the HDD to load about 10G of music in MP3 Format. It loaded each track one at a time and took a long time to do each one They are all in the root directory, about 3500 of them
                          • You're right, I ought to use that search function
                            I wasn't going to leave a SD in there, but I'm thinking it might just be a good idea after all
                            • You dont need to search just start on page 1 and work through it Thats how we have learnt, Its all there.
                              Same questions all the time when its all there already.
                              • My (bad) experience with WA AHG Volkswagen Dealer and firmware update
                                Recently during my annual service to my Nov'12 Scirocco R I posted an email to the service representative first asking if they have the technical experience and hardware to check and upgrade my fitted RNS510 unit and secondly what it would cost?
                                They replied that they did and the upgrade would cost AU$80.
                                My RNS 510 details are:
                                Delivery Part Number - 1T0035680D
                                SW-Version - 4020
                                Maps - AU & NX, Supplier Sensis
                                Map Version HDD -7005
                                I explained that I wanted the SW-Version and the Maps upgraded to latest and gave them links to this thread and other information that explained there is a newer version for the 680D.
                                When I picked the car up and checked all they had done was upgrade the Maps to HDD - 7920 but NOT the SW?
                                Asking them why they hadn't upgraded the device as they had quoted they told me that the latest SW-Version was on the device according to their testing equipment?
                                Since then I have had no success getting a refund or in fact any comments about it at all!
                                I contacted another VW Dealer (John Hughes) here in WA and asked them the same and they told me to come in and for NO Charge they would check and upgrade my RNS 510! So it is booked in tomorrow morning and WE WILL SEE?
                                Does anyone on this forum know how the dealers check these units, you would think they would be trained by VW to handle these systems on their vehicles? Servicing is not just spark plugs and oil change these days!
                                Any comments would be appreciated, thanks?
