Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
  • Thanks I'll try
    • Originally posted by Hillbilly View Post
      Should be able to. Try it and see
      Hi,I put the map v.15 but I can't change current position.Do I need upgrade sw from 4020 to 5238.Thanks
      • Originally posted by Sijalica View Post
        Take the car for a drive. The GPS will reset to find the satellites. Takes about 5 - 15 minutes of driving around to do it.
        MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
        2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
        • Skoda is first been in Holland and map is been West Europa,I put map v.15 East Europa and Navigation always start from current position in Holland but I'm in Bosnia and can't change current position
          • In current position ;sattelite 0/11
            • Why alwayes 0 tracked sattelite,can Kamold some help?
              • Does the unit show open circuit fault for GPS?
                Sent from my SM-G960F using Tapatalk
                • Go outside and drive around for a while
                  • VCDS say open circuit when I pull out GPS conector but in GPS setup say antena conected when
                    antena in pleace ,and why gps say 9 or 11 satelite visible but 0 trackedClick image for larger version
                      antena in pleace ,and why gps say 9 or 11 satelite visible but 0 tracked[ATTACH=CONFIG]48655[/ATTACH]
                      Thanks Kamold and everyone,I buy gps antenna and solve problem
                      • Can I put this 5238 sw from Kamold for car in Europe
                          No, as it will not leave enough space for EU maps.
                          Au maps are only 800MB.
                          • Just used this thread to recover from corrupted firmware - RNS reverted to German. Huge thank you to kamold for the excellent and detailed instructions!
                            2011 MY12 RS Magic Black liftback. Bit of bling and a massive grin.
                            • Good Morning im looking for some help to sort out my. RNS510 fitted in my VW CC 2013 the issue is that every time I get in to the car the unit reboots the specs are
                              Delivery Part Number 1T0035680L
                              HW-Version H09
                              Software Version 5238
                              map Version 8207
                              any help would be greatly appreciated
                              thanks
                              • Try reloading firmware 5238.
