Custom POIs with 3xxx firmware, Aus/NZ Maps v 4.1 and POInspect0r
Version number would tend to indicate the real thing.
I'm prepared to call this myth plausible
Does this assist in the quest for the truth... I have no idea... as I said, I picked the car up today and it is my first VW.
Oh.. it was a sealed package as well.
Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
that sure does look plausable
my v4 maps is "7360".
according to ur info, v5 = "7679".
this from my v4 cdrom.toc file:- Continental Automotive GmbH
I IC RD G SW NM DB
Content
Volume: CD_7360
Date: 9.9.2010
db: AUNZ(2009Q4)
Area: Australia + New Zealand
Supplier: Sensis
Version: 505.99.981.84
Customer: 1627387139
Customer Info: VW
Features: ZIP3kb - feaV10(VW)
TPD: 2010065002
SVD:
TMC: no
Phoneme: no
DBAL: V005_015,V006_024
so andych......where do i line up to get a copy of this v5 dvd map?
i'm in sydney this weekend.
I can certainly help with transferring custom POIs onto a V5 map.
But can you show us a bit more leg Andych?
Post up the contents of a file contained on the disc called cdrom.toc.
You'll need to open the file with either Wordpad or MS Word.
Then all shall be revealed ... kinda like this (being a V4.1 map that I've modified to include custom POIs):
But hopefully looks like this (containing a fcuking proper map update):
So is this enough of an update??
I am not sure if they have updated mine or not.....
OK... New maps loaded up although I will most likely go the custom firmware for 50 - 25 - 25 soon.
From what I can remember in the setup options there is now Lane Guidance.... you can set the average speed for arrival time... ie Fast Med and Slow.
The map update is Q1 2011... so whatever changes that brings as well.
No doubt there will be more or the things I have mentioned were there before and I missed them... I only picked it up this afternoon... so there is plenty to learn.
Lane guidance is present on my A version unit with FW3810 and V4.1 maps
Well there you go... I missed that earlier.. I must have been too interested in driving it... lol
