Custom POIs with 3xxx firmware, Aus/NZ Maps v 4.1 and POInspect0r
Try this. Load the disc with the kamold build (ignition key out of ignition). Wait until you get the error message that you've described. After it comes up simultaneously press the Setup, Eject, and Info buttons on the RNS 510. This should force the disc to boot and install the kamold version.
Perfect bottom scratcher worked a treat. My last tweak is the voice control button on msfw doesn't give me the same options when I hit the star button the the rns. Coding I believe, anyone know the codes I need?
*edit* thx for the info
I would love for this to work as well, i find the mic button on the steering not as good as the commands available using the star button
I picked up my Scirocco today and will be looking at sorting out some POI's etc... The Disk that came with my car is V5...
Has anyone else looked at V5 and what the changes are?
Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
do a copy of the disc....link it up in a shared site, and we'll let you know if there is a difference
I am creating an ISO from it right now.
