T5 Performance Tuning: Who's done it?
  • #46
    T5 TSI Tuning
    Whilst searching the web I found this
    348kw TSI T5 upgrade VW T500 MTM Tuning - 2,5 TSI 348 kW (472 hp) 4motion
    and more sedate tuning options 199-221kw VW T5 Facelift Tuning - 2,0 TSI 150 kW (204 hp) Front
    Awesome ....
    Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2018 MY18 Golf 110TSI (150TSI) Trendline manual White2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
    • #47
      I do now Autologic performance tunes. Currently have it in my T5 4Motion and I like it. I can do you a special deal, so you can test it and pass the comment.
      The difference that I've noticed is that with al tune the turbo is not on the boost right from the idle, like with some other brands. So, the longevity of the turbocharger and the engine is less affected.
      Transporter, are you still doing Viezu tunes?
      2014 T5.1 Multivan Tuned by Pendle Performance Australia
      • #48
        Yes I do. Why?
        • #49
          Awesome ....
          Pretty impressive. Hate to think what this would cost. They fit an Audi motor in it. Check out some of the acceleration videos on youtube, they will blow you away.
          • #50
            Does anyone know if any of the engine tunes are potentially possible on DSG-equiped vans? I heard that DSG includes something called "Torque Limiter", which might mean some sort of conflict whereby more Nm from the engine tune may not be allowed thru by the DSG? There are places offering a service of removing Torque Limiter. If someone could explain this, would be great.
            Multivan MY12 TSI350 Red. Previous: 2008 Tiguan 103Tdi. 2010 Tiguan 125TSi.
            • #51
              DQ 500
              For the best results & longest life out of the DSG (with stock engine or a "chipped" engine), it's best to do the DSG software. Clutch life is extended enormously, and the torque limiter in the DSG is modified to suit the engine output.
              The Oettinger software upgrade is here:
              Oettinger Sportsystems GmbH - Products
              The 132 specific details are here:
              • #52
                Contact Oettinger dealer in Australia. A product is available that will give you 184kw/400NM, turn that Bus into a sports car (almost)
                Oettinger Sportsystems GmbH -Â*Products
                PS: Missed Guy's post above. What he said ..... except you have the TSI not the BiTDI
                • #53
                  Originally posted by Guy_H View Post
                  DQ 500
                  Hi Guy
                  Do you have a similar software upgrade for the 128KW 6 speed TDI T5? Would that help with the flaring between 2-3 or is that another issue? Can the software be upgraded prior to a decision about which tuning option is taken as the output would be unknown at that stage?
                  Thanks
                  Michael
                  • #54
                    Auto is the problem for "flaring"you should get the auto serviced but if you do make sure they change the filter inside or you will be sorry later . BUT be warned even a service fluid change etc may not sort out the problem some reports have said that sometimes after servicing they can be worse . The mechatronics can over time get a build up of muck around the valve bodies if you flush it out with new fluid it can some times make it worse !! Take it from me either way there is a risk . We were told by VW that there was a software update to fix the "flaring " but after they serviced ours it we had complete failure 5 kays from the dealer they DID" not" replace the filter only the fluid it then blocked the filter with leftover muck which deprived most of the moving parts with lube and total destruction was the result .$10.000 repair bill only 130.000 kays. Please no need to ask more as this has been chewed over many times before on the forum .
