Wondering if anyone has experience of these poly bushings on a t5.1? Good / bad / no difference? Where did you purchase them from?
Story is I just got some new tyres, went to get a wheel alignment and mechanic said wheel alignment would be a waste of time unless I replace bushings and get new suspension top mount bearings. Quoted $330 for the new OEM top mount bearings etc, though it appears the sachs / boge gear from just kampers is a lot cheaper - VW T5 & T6 Front Shock Absorbers :: Just Kampers Australia any comments on these ones? I'm a bit paranoid after years of t3s syncro ownership and never knowing which replacement part would be best - it definitely wasn't always the OEM ones!
Last note there is the suggestion I should change the front shocks whilst everything is removed, though I was planning to do suspension a bit further down the track. Front shocks seems ok, I assume they have a lot of km on them. Anyone by chance have some good stock 4motion shocks sitting around they would like sell?
Cheers, Sam
Cheers, Sam
