Secondary air pump problems
  • #46
    Originally posted by leitch View Post
    Interesting about the resistors - where's the fourth supposed to go? Two for the stuff up top, the bigger straight resistor for the wiring that plugs into the SAI pump under the inlet manifold, and where else? As I said I was following Anthony and Noone's write ups, and neither mention a fourth resistor.. I could have missed something, though, I can be a bit hasty like that at times.
    Hastiness is also most likely why I lost more coolant, though it was less than others have reported.
    The SAi pump mate, you use 2 of the big resistors, not enough resistance with the 1.
    Jmac
    Alba European
    • #47
      Originally posted by noone View Post
      It would be easier. If I do it again, thats what I will do for a while, just to make sure it does not throw codes. You'd have to clamp of the vac line too, most of us are trying to remove junk from the engine bay, so a good reason to go to the extra effort (in the long term).
      Jmac, I didn't clamp anything, that would be why I lost a lot of fluid. Not experienced like you my friend.
      Agreed the bay is way cleaner looking with it removed, worth the extra effort i reckon. Wasnt being smart about the coolant loss, only trying to help.
      Jmac
      Alba European
      • #48
        Jmac
        Fair enough, that was the only other thing I could think of, but I figured it was also the reason IntEng offered the larger different resistor for the SAI pump. Anyway, still no CEL after probably ~600km so if it does eventually pop up I'll chuck another one in.
        '16 Octavia RS Wagon
        Past - '07 Polo GTI
        '08 RenaultSport Clio 197
        • #49
          Hm, wonder why no one else threw a air flow code...
          • #50
            Hmm would be because of the above statement, the larger one probably does do the trick.
            Jmac
            Alba European
            • #51
              Yeah thats probably right mate, the larger resistor probably does the trick.
              Cool
              Jmac
              Alba European
              • #52
                Organised another SAI for my car, for anyone that's wondering the combi valve part no. is 06A131101D.
                2007 MY08 VW Golf MKV R32 Blue 6M 3-Door
                2006 9N3 VW Polo GTI White 5M 3-Door
                • #53
                  selling my combi valve if any one is interested.
                  Polo 9n3 GTI
                  • #54
                    Did a VCDS scan today and it came up with 16795 - secondary air injection system incorrect flow detected P0411-35-00-- so thinking of removing mine. Is that the best option? Where can I get the blanking plate and resistors from?
                    Cheers,
                    Scott
                    Red 2006 Polo GTi : Forge Splitter - TIP - ITB - Forge Front & Rear Strut Bars - Dash Cubby - Fumoto Valve - Full Milltek Exhaust - PD160 Intake - K&N Panel - ECS Stage 1 Clutch - Seat RCA Bushes - APR Stage 1+
                    • #55
                      Hi mate,
                      Can i ask where you sourced your pump from?
                      Cheers,
                      -Phil.
                      • #56
                        Originally posted by philthy View Post
                        Hi mate,
                        Cheers,
                        -Phil.
                        Way cheaper ditching it mate
                        Get all the bits from integrated engineering
                        Jmac
                        Alba European
                        • #57
                          Hi mate,
                          Cheers,
                          -Phil.
                          Bought it from here actually. 2nd hand from clicht.
                          • #58
                            Philthy
                            I just removed one from my S3 which is the same part number. If yours is dead mine still works, sounds a bit noisy but you can have it for beer money if you need one.
                            • #59
                              Thanks for the offer Gavin. Mine still works, just makes a racket. Should probably just do as I'm told and blank it off.
                              • #60
                                I reckon Jimmy is right. No point in wasting money on it.
