9w7 Bluetooth kits back in stock @ vag-navisystems from spain USD$249 + Post
  • Originally posted by readerr0r View Post
    Did they tick 77-telephone in the CAN Gateway installation list?
    • Originally posted by gavs View Post
      Yeah who would forget to do that
      • Not I I installed it on the list before the module even went in
        Stuffed if I can get the damn phone menu to come up on my MFD when I press the phone button on the steering wheel though....
          Interesting, Ross-tech still hasn't given us a helper file for the steering wheel. Whats the coding for yours?
          Its the MFL unit in the central electronics section.
          • I thought we could only change the function of the microphone button between pause/mute + voice control. Have never never seen anyone successfully change the function of the telephone button.
            Audi A3
            • Originally posted by Ryan_R View Post
              What's the coding on this one? Sick of accidentally pressing it whilst turning.
              Mk8 Golf GTI
              • Originally posted by ill0gitech View Post
                Untick the top one like in the pic, and happiness will follow you
                • I usually change that setting via Module 16 - Steering wheel:
                  Change the 5th digit to 1 or 5 if you don't have DSG paddles or 2 or 6 if you do have them (Polo GTI).
                  Audi A3
                  • Not sure, JexL is playing with my cable at the minute
                      Steering wheel doesn't have its own module in the Polo, it's a "slave" of the cent electronics unit so it's actually quite a bit different.
                      • Much appreciated
                        Mk8 Golf GTI
                        • Hi Readerr0r, 77 was ticked in the CAN Gateway. I think the VW VAG tool at the dealership was the problem. I got a RossTech VCDS and was able to code the 9w7 easily. The problem I have now is it comes up with a fault code saying open circuit on the mike and my iphone recognises the VW PHONE but when I try to pair it, I get a message saying "Make sure PIN code 882827 (code changes every time) is shown on"VW PHONE" "CANCEL" "PAIR" and then I get a message saying Pairing Unsuccessful Make sure VW PHONE is turned on, in range, and is ready to pair.
                          Address 77: Telephone (J412) Labels: 7P6-035-730.clb
                          Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
                          Component: TELEFON H15 3200
                          Revision: 1B001001 Serial number: 00007662633888
                          Coding: 0A01000000010110
                          Shop #: WSC 00000 000 00000
                          ASAM Dataset: EV_UHVNA 002720
                          ROD: EV_UHVNA_VW46.rod
                          VCID: 3A710BC9BDD9C3C82F1
                          1 Fault Found:
                          9455635 - Telephone Microphone
                          B1048 13 [008] - Open Circuit
                          Intermittent - Confirmed - Tested Since Memory Clear
                          Freeze Frame:
                          Fault Status: 00000001
                          Fault Priority: 4
                          Fault Frequency: 4
                          Reset counter: 167
                          Mileage: 74676 km
                          Date: 2037.14.03
                          Time: 11:28:16
                          MY 13 Golf R. APR Stage 1. +DSG software upgrade.
                          2013 Passat Alltrack 130 TDI
                          • Fault code means the coding you've entered makes the car expect some new wires somewhere but isn't finding them. Not a massive deal if everything is working. My car might even have the same fault since swapping 9W3 for 9W7.
                            As regards the PIN code, you can change it via VCDS. Have a look at Page 15 of this guide: https://docs.google.com/file/d/0B4fM...lzcEVJTlk/edit
                            "Step 15.2.4.7: Check that channel 135 = 1234" 1234 (or the value you enter) will be the PIN code you need to type in on your phone.
                            Audi A3
                            • Originally posted by prrow61 View Post
                              1 Fault Found:
                              Freeze Frame:
                              Fault Priority: 4
                              Fault Frequency: 4
                              Reset counter: 167
                              Mileage: 74676 km
                              Date: 2037.14.03
                              Time: 11:28:16
                              For those guys with the fault code in VCDS "Telephone Control Module - open circuit" this means it's looking for the 3-button Bluetooth control module in the roof. You need to change the coding of the 77- Telephone module to "Control module - Not installed" to get rid of this error (I think the default is 3-button or something similar).
                              • Cheers, will have a look for it, any clues where it is?
                                Audi A3
