Polo GTI High Oil Usage - Discussion Thread
This is a sticky topic.
  • Polo GTI High Oil Usage - Discussion Thread
    Originally posted by Yaks1974 View Post
    Ok this is my theory..... All 1.4 twinchargers have some kind of design flaw in that they have noticeable oil consumption and exhaust soot during low engine speed (below 2000 rpm). By not using the D mode at all ( which is designed to keep revs very low and thus improve fuel economy) these people are seeing oil consumption improve to around 1L/8000 -10000km and cleaner tailpipes.
    Not a bad theory but the only reason that there are issues is because of sh*thouse manufacturing. The higher rpm is also generally attributed to lighter throttle application so there is less pressure in the combustion process due to lighter load. Yes it's a band aid solution but that's not the point.
    The point is that there shouldn't be any need for the consumer to have to accept a substandard product just because the manufacturer is too stupid to fix it.
    • Maybe just remove the supercharger belt?
      Resident grumpy old fart
      • Originally posted by gavs View Post
        Maybe they can't easily fix it...
        It's like Mazda and their new SkyActiv Diesel. It was a mess when first installed in the CX5 (massive crankcase oil dilution with diesel). And the response from Mazda was similar to VW. Took 8 months for a "solution". Not to mention their spontaneous burn the car to the ground iELoop in the Mazda 6.
        • Anyone tested their engine with a different weight oil or is everyone too afraid to void their warranties?
          2012 Fabia II VRS Estate - APR stage 2 tune, Custom 2.5" turbo back full stainless exhaust with ceramic coated dump pipe, Harding Performance Cold air intake, Wagner Tuning Competition Intercooler, GFB DV+ diverter valve, Braille B2317RP battery, Eibach pro kit springs, Bilstein B8 shocks, Harding Performance F+R ARB, Super Pro bushes, Porsche 986 Boxster S front brake calipers, 330x28mm front rotors, Ferodo DS2500 front pads and Remsa rear pads, Enkei RPF1 17x8 et.35 with 235/40R17 Yokohama AD08R tyres, Maxton front splitter and Superskoda fender flares.
            I have to agree with this. If I wanted to drive a car manually all of the time I would have bought a manual car...
            On topic, has anyone concluded whether they use more oil doing city or highway runs?
            For me, the only time I noticed a significant difference was during some really hot weather (35-40 degrees) when my car used 3-400ml in about 800km. Prior to that it was averaging about 1L per 4000km, and since it's used about 750ml in 4000km (there was an oil change in that 4000km, though).
            Now gone.... 2012 Skoda Fabia RS
            • Originally posted by Rubbadub View Post
              Exactly. If I had wanted a car with the performance of a Golf GTI but with the fuel consumption of a Golf GTI, I would have bought a Golf GTI!
              The fuel economy was a big selling point. VW should fix THEIR problem, not oblige me, the CUSTOMER, to work around THEIR problem...
              2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
              Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
              1st Ride: 1988 Red VW Fox Sedan!
              • Re: Polo GTI High Oil Usage - Discussion Thread
                At 1700km checked the oil in the fabia vrs, it was just above (b) section in (a). But never checked it in the first 1700 so not sure where it was to begin with.
                Did a +300km day trip earlier on in the week and missus has now driven it abit more so i checked it last nite and has dropped about 3mm and took just over 100ml to bring it to back to (a)
                Cars got about 2200km on it atm.
                Cheapest 1l top-up bottle was $28 at highway VW , southport VW was $32
                • Originally posted by pologti18t View Post
                  The have been able to easily fix the problem. They're stopping production of the engine! Nothing more simple than pressing the off button!
                  mmmRacer, Petronas make a 5W40 oil that meets the 504/507 specs but I have spoken with people running 0W40 oil in europe and it has done nothing to subdue their consumption issues, they may just have very out-of-tolerance examples of the engine, if your engine isn't that far out of tolerance, a 40 series oil might help maginally.
                  • Hey Guys,
                    Got my oil check report back, seems as though everything is ok and that i should just monitor again at next interval. As you can see in the report it was flagged that i have a high silicon count and maybe thats due to the engine being still relatively new?
                    Anyhow will redo again at the next oil change interval and report back.
                    Anything else you guys can see thats interesting?
                    • Wow, good result there! Interesting how after 21K has a high silicone count.
                        I'd be interested to see what results other people get. Slightly interesting is the iron content at 32 points, where the caution threshold is greater than 45.5. Still moderately high, won't know until next oil check, or if someone conducts similar analysis.
                        • Originally posted by ehsteve View Post
                          Thought I would stoke the fire a bit.
                          Partner's MY13 Polo GTI CTHE needed an oil top up yesterday after the light came on at 3000kms. Couldnt get onto VW at the time so filled out of my own pocket. Called VW (where we bought it from) this morning informed the lady at the service desk. She was shocked to hear it had burnt that much and wanted us to bring it in. I asked to speak to a mechanic or a foreman. She went off and had a chat, and he wants me to bring it in for a supposed fix. I enquired what this fix was, but the foreman just left so she couldnt ask, but apparently it was not changing any parts.
                          I also enquired whether, in future, I was able to come down for a free top up this early on, and she seemed surprised that I asked. How did you guys get VW to top your oil up free of charge?
                          With regards to the "fix", everything on the car is perfect. After hearing stories on here about the driveability suffering after an update or whatever I am hesitant to hand it over.
                          I also got fed the "run in oil" story. Is this honestly a load of crap? Is there any difference in viscosity between their oil, and ones we buy off the shelf?
                          Just checking in again. 1000 more kilometers, I noticed along the way it was burning a bit, but wanted a wider average so let it burn half way down the b section. However it only let me top up about 200 mls curiously. I'm gonna drive it for a week and see of the consumption changes with a heavier foot. Also with regards to the soot, what does it look like? And is it all over the back? Or only near the exhaust?
                          • Should not have so much iron. Are you using original air filter system or you changed something? Fuel dilution is higher than my own comfort level. Lastly, how many times have you changed your oil?
                              Checked again today after another day trip. Took about just over 150ml to top it up. Done about 500-600kms since first top up but 300ml all up at 2800km isnt overly excessive?
                              • Originally posted by muli View Post
                                Nope. Should improve as the mileage gets up
