Originally posted by mrkris
View Post
Polo GTI High Oil Usage - Discussion Thread
This is a sticky topic.
Interesting to have a bit of a search around for oil and various performance cars and it's pretty common to read tales of oil use in M3s M5s etc. Looks like it's a price to pay for this car, unfortunately it might not be hi-per enough to justify the tlc and retain resale value like an M car though. It is to me though. Mine isn't outrageous at this point so only being 7500kms in I'm hoping it continues to settle down.
they devalue just like the rest of themOriginally posted by dening View Postunfortunately it might not be hi-per enough to justify the tlc and retain resale value like an M car though.
the guy with the m3 paid 50k and the guy with the m5 paid 90, both low kms. thats a HUGE depreciation (i sure as hell couldnt afford/justify/pay enough tax to take a hit like that)
Good luck with your car!Originally posted by dening View PostMine isn't outrageous at this point so only being 7500kms in I'm hoping it continues to settle down.
If you believe that your car is faulty and wish to be considered in possible class action, please register your interest here:
VW Class Action Under Investigation : Complete the Questionnaire
What does this have to do with High Oil use???? The class action is something about DSG issues, isn't it?
Originally posted by RossP View PostIf you believe that your car is faulty and wish to be considered in possible class action, please register your interest here:
CheersOwner and Operator of 2013 Polo GTI - Sunroof - Xenons - Reflex Silver
APR Stage 2 Tune - HP Carbon Airbox - Jetex Stainless Cat Back Exhaust - APR I/C
Plus a few other bits and pieces.
I have done 1100 kms (delivery 15 May) and the oil level on the dip stick has gone down 2mm (I checked the level when I took delivery). I know I'm neurotic but what usage might that equate to?Originally posted by steveyoshi View PostMY 2013 Polo GTI - 250ml in 1270 kms from new.2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
What I was hoping for thanks Rubbadub. So far so good.Originally posted by Rubbadub View PostFrom memory, from top to bottom of the cross-hatched (AKA "B") section is about 1/2L. So 2mm would only be about 50-100ml.2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
Re: Polo GTI High Oil Usage - Discussion Thread
Sounds about right, last time i topped up was about that and was a good 150mm.Originally posted by kawabanga View PostShould be about 1 liter from top to bottom of the cross-hatched area, so 2mm should be about 100-150ml, considering that that area is divided in about 13 squares and that one square is about 1mm
Actually engines still warm as just got home so might go check it.
BTW anyone got any funky lumpy jumps when it first starts cold? No noise just bouncy.
Few times ive gone to overtake lately and its felt like it looses boost then spools up and changes gear.
Happens between 2-3 gears,run caltex 98 in the car.
Maybe TRC?
Mine lumpy at cold starts and recently lumpy even with warm engine at idle. plug in vagcom nv shows anything abnormal. I suspect might be injector issue or the cam positioner issue. Spark plugs are burning healthy with no fouling and light brown in colour.Originally posted by muli View PostSounds about right, last time i topped up was about that and was a good 150mm.
Maybe TRC?
youll need a hexcan cable from rosstech which comes with vcds software. there are cheap clones available from places like deal extreme but your milage will vary and the software they provide does have viruses and cant be updated (otherwise it will brick the cable)Originally posted by muli View PostVagcom? Where and how much?
Is there a reason why it only happens when cold
its' $250US vs $19 aud delivered.
