Polo GTI High Oil Usage - Discussion Thread
This is a sticky topic.
  • So after 3 months and 2500km since my engine rebuild, my engine oil was1/4 down the dip stick. 250ml topped up and full again. I think I can live with 1L/10,000km, much better than the 1L/1,000km I was getting before the engine rebuild.
    Fingers crossed it doesn't get worse.
    • 2100km on mine and the oil level has just come down to the top of the cross hatch area. The oil level when 'delivered' was about 4mm above the cross hatch area and just below the flange. Would this be considered overfilled from new?
      2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
      • Yes, over-filled. It should be about 2mm below the top of the x-hatched section with 3.6L in. Maybe some garages are getting confused with TSI engines and putting 3.9L in.
        Now gone.... 2012 Skoda Fabia RS
        • rubbadub. Don't you mean 2mm above top the x-hatched section?
          either way, there is usually a photo/sketch in the owners manual showing levels A (max fill); B (safe area) & C (minimum level).
          • Originally posted by brad View Post
            Yes it's supposed to be slightly above that middle xxxxxx area.
            Look in the manual.
            • Originally posted by Andypoo View Post
              Look in the manual.
              2mm above is about what the manual shows and I expect that 2mm over that recommended level is not a real big deal.
              Good to know the oil capacity (3.6litres) of the GTI though. I've been through the manual several times and could not find it (the oil capacity).
              Thanks fellas!
              • Originally posted by car_nut View Post
                Thanks fellas!
                Indeed.
                Performance Tunes from $850
                Wrecking RS OCTAVIA 2 Link
                • I stand corrected. A couple of guys on Briskoda with the same engine reckon they changed the oil and refilled with exactly 3.6L to just below the top of the cross-hatching. Maybe the Polo GTI is slightly different. As long as you don't go and add half a litre now, a couple of mm won't make much difference.
                  • Engine oil capacities are approximate, so if someone puts 100ml more oil than others to get the oil level to the full mark on the dipstick, I wouldn't stress too much about it.
                    • Polo GTI High Oil Usage - Discussion Thread
                      Have a look at my avatar, that will show you the marks. Full is the bottom of the top, sausage shaped orange bulb on the dipstick.
                      • MY 13.5 CTHE engine polo GTI, I've had it a week and driven it 500 km (a few longer trips to go rock climbing recently). Checked the oil this morning and it hasn't gone down from a few mm above the cross-hatched area since new, it does look ever so slightly darker than when new now but it used to look almost like water. I've been fairly careful with it, letting it warm up before giving it some power and keeping the RPM down most of the time, hopefully things will stay as good as they are now.
                        MY13.5 Polo GTI - Flash red
                        • Re: Polo GTI High Oil Usage - Discussion Thread
                          Just over 7000km's and another 200ml went in so total of around 1.2L.
                          Letting the missus do all the driving
                          • Jinxed myself... Polo gti just hit 3100kms and oil top up light has come on... Taking it to vw tomorrow
                              Have you been checking the oil? I notice if i gota top up between 200-300ml it idles louder or maybe just placebo
                              Sent from my HTC_PN071 using Tapatalk 2
                              • Nah i havent been checking it but yeah after the guys at vw topped it up. It idles louder!
                                But its kinda worrying when i heard they say it lost a whole heap of oil (dunno if i heard it right but i did hear him say 1.5 litres??) over the 3100kms.. So they told me to come back after 1000kms.. And if it has dropped 0.5 litres in that time, ill have to bring it in and im not sure what goes on from there...
