Does this JB1 thing void your warranty?
New Passat 206TSI R-Line
well.. the theory of piggyback is that it intercept signal from the sensors (only 4 plugs/sensors), and provide the ECU with altered input, so it will calculate the data differently. So it is not a re-tune/re-map kind of setup. And hence... if you unplug it before handing the car back to the dealer, it should not be detactable.Originally posted by TailsK View PostDoes this JB1 thing void your warranty?
And you can take it in and out quote easily as it is only 4 connect point (3 on top in the engine bay and one under, which you need to jack the car up)MY13.5 Rising Blue Scirocco R - DSG - Sunroof - sold!
MY15 Pearl Black Tiguan 155 R-Line - DSG - Dual Sunroof - SatNav - Leather - sold!
MY17 Indium Grey Passat 206TSI R-Line Wagon - DSG - Dual Sunroof ... the Journey Continues ...
Check out my blog for car photos and product reviews! http://www.infiniticious.com
All advice, even from the dealer, says it shouldn't. It doesn't flag a TD1 fault like a flash tune does. The reason I had one installed was because I drove a VW dealer demonstrator sedan with a JB1. The CFO's car. It only had 60k's on it. As and when you want it removed, just unplug it.Originally posted by TailsK View PostDoes this JB1 thing void your warranty?
Sent from my SM-G930F using Tapatalk
Does it induce any noise from the exhuast/engine? (just want to see if it will pass the daugther/wife test, aka... sneak it in without them knowing)Originally posted by AZ_Wagon View PostAll advice, even from the dealer, says it shouldn't. It doesn't flag a TD1 fault like a flash tune does. The reason I had one installed was because I drove a VW dealer demonstrator sedan with a JB1. The CFO's car. It only had 60k's on it. As and when you want it removed, just unplug it.
It sounds exactly the same to me. Obviously under heavy acceleration there is engine/exhaust noise but I would challenge anyone to tell the difference.Originally posted by SciroccoJ View PostDoes it induce any noise from the exhuast/engine? (just want to see if it will pass the daugther/wife test, aka... sneak it in without them knowing)
The car drives much as it did before with moderate throttle control which will be the give away if moderate throttle control is not used.
......It is however noticeable when the installer of the JB1 puts their sticker on the back windscreen. That's how I was sprung!
Awesome! and $699 installed is a great deal. It cost pretty much the same landed here in australia when you added the data cable and shipping....Originally posted by AZ_Wagon View PostIt sounds exactly the same to me. Obviously under heavy acceleration there is engine/exhaust noise but I would challenge anyone to tell the difference.
Sent from my SM-G930F using TapatalkMY13.5 Rising Blue Scirocco R - DSG - Sunroof - sold!
......please give them a call first if your going to Hill Eurohaus. I think I got the last one in stock and they were going to wait for the JB4 to be available rather than order more JB1's. Hills are going to upgrade mine to a JB4 when the firmware update is available.Originally posted by SciroccoJ View PostAwesome! and $699 installed is a great deal. It cost pretty much the same landed here in australia when you added the data cable and shipping....
Also, if you are going to use Hills Eurohaus, give me a shout as I work across the road!
Has anyone done any VCDS tweaks yet?
So far I've
- Enabled Traffic Data
- Enabled Sign Recognition (not that fantastic in AUS because our signage standards are terrible)
- Permenantly disabled stop/start
- Enabled needle sweep on startup
If anyone wants to do any of the above and needs some tips then I'd be happy to do up a quick how-to. Obviously a VAG-Com Cable and VCDS is required.MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
Wow... thats impressive.... I dont know if my old cable will work on the new passat (it works on the 2015 Tiguan I had).Originally posted by Wynnston View PostHas anyone done any VCDS tweaks yet?
So far I've
Can the Start/Stop be programmed to be off by default (but you could still switch it on if you want to) instead of disable permenantly?MY13.5 Rising Blue Scirocco R - DSG - Sunroof - sold!
It should work - it's the same comms interface and you just have to make sure your Vagcom software is up to date.Originally posted by SciroccoJ View PostWow... thats impressive.... I dont know if my old cable will work on the new passat (it works on the 2015 Tiguan I had).
Start/stop is disabled by adjusting the min battery voltage required to go into start/stop (car won't do stop/start if your battery charge is low). So if you set the min voltage to (say) 14V then the battery will never achieve this and so car will never go into start/stop.
Otherwise you have to press the button to deactivate it every time you drive. Start/stop was suspected to have had some part in premature turbo failure in a number of earlier MQB platform cars as hot turbos were stopped (by start/stop) instead of gently running (idle).
