Finally got some good news to report - the final piece to the puzzle, the AFS_MDF data file, was successfully loaded, via ODIS, into the 4B module and the SLA (Skoda's version of DLA) functionality is now fully operational.
No errors. wooOoot
I went for a quick test drive and its certainly doing the fancy masking with the auto high beams, as expected.
A BIG BIG thanks to Kamold and Magnus with their assistance, and patience in sourcing the parameter file.
No errors. wooOoot
Is there anyone on here from WA that's got the tools. I am not fond of buying knock-off cables and the real deal is expensive just for a single coding job.
Maybe you could sell it on after using it, or form a consortium of other guys in your same situation (only need it for a single use) and send it on to them once you've used it?
2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC| 2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|3D colour cluster|Quad LED tail rings|Climatronics upgrade|Dynaudio retrofit|B7 RLine Flat Steering Wheel|3AA CCM|TPMS Direct|B7 Adaptive Cruise with Front Assist|Discover Media retrofit|PLA 2.0|Lane Assist|BCM retrofit|High Beam Assist|DQ500
Good idea. "Kamold, the voice of logic and reason"
Module 09 - Central Electrics
Erweiterte_Fernlichtsteuerung
New value: AFS, FLA, Fernlicht (GLW,MDF)
The other two requirements were already set to present due to HBA already being active.
A5 Front Sensors Driver Assistance System
New value: 000307060000010100022346C150A90098000E300040
4B Multifunction Module
New value: 000000050900084E07004F010A000000000000000000000000 0000000000
I then hopped out the car, cleared the headlight fault, ran basic settings, acknowledged the basic settings & cleared the headlight fault again. It cleared and all seemed good.
Jumped back in the car, saw that Dynamic Light Assist was ticked in the head unit. Pushed the high beam stalk forward and received "Light assist error"
I tried to follow the next steps in the guide if you received a light assist error. I completed the coding but was unable clear the headlight fault and run basic settings. OBD Eleven kept saying that there were minor errors preventing it from running.
Any help is appreciated.
Reason: Vehicle clarification.
I am not sure it will work without a proper parameter set for the 4B multifunction module....this has been my experience with both Passat B8 and Superb 3 DLA.
The 4B module long coding on mine is
000000050107104F010A0000000000000000000000000000
By parameter set you mean the basic set of available functions programmed into the module from the factory? Sorry, newbie here.
i also had the "Light Assist" fault after i retrofitted the SLA (DLA for Skoda).
once the correct 4B parameter files was uploaded (via ODIS), thanks to @Kamold, it was all good.
there r 3 types of parameter files for 4B:-
1. Level Control Only
2. AFS
3. AFS with MDF
mine had the "AFS" parameter file from factory.
we uploaded "AFS_with_MDF", and all was good after.
