Hi All,
I have just enabled DLA for a B8 Passat.
There seem to be a number of possibilities with respect to BCM and headlight range module combinations, so this is still under investigation...hoping this might be possible to achieve with just coding and adaption - keep watching this space.
Dynamic Light Assist
Dynamic Light Assist < Technical Glossary < Innovation & Technology < Volkswagen International
Thanks to DR074 for the link to instructions here:
Activate Dynamic Light Assist (DLA) - up to MY 2017 - VCDSSchweiz
There is a VCP parameter set for Passat B8 with highline LED and A3 with Matrix LED but this is only required to change the light startup sequence (the headlight dance). It is possible to fully enable the feature with just coding and adaptation through VCDS.
NOTE: if you have the older VCDS HEX-USB or HEX+CAN it is NOT able to see a module at address 4B. This is the address of the headlight control module in newer Tiguans.
VCDS V2 interfaces and VCP can see and change settings in this module.
Will update once I test OBD11.
