Hi Kamold,
I try to install the ACC-System on my Passat B7 wagon too. But the ABS-hydraulic block won´t accept the coding. I bought, depending on the Information that I found in your thread, the ABS hydro block number with letters AR. Is there an additional step needed before the new code is accepted from the ABS ?
Hi Kamold,
Need some more information - ideally a full VCDS autoscan.
2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC| 2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|3D colour cluster|Quad LED tail rings|Climatronics upgrade|Dynaudio retrofit|B7 RLine Flat Steering Wheel|3AA CCM|TPMS Direct|B7 Adaptive Cruise with Front Assist|Discover Media retrofit|PLA 2.0|Lane Assist|BCM retrofit|High Beam Assist|DQ500
Modify the ecu software to not log the fault.
If you can get a read of your ECU with something like KESS, MPPS, Galetto etc I can get it modified to remove the ECU side fault which stops the issue from causing a braking disengagement situation.
thank you for the offer. I have a colleague who I could send an identical ecu to, which he could then read out. Does he have to flash it with KESS again or can I do it with VCP?
If it's read with KESS will need to be written again with KESS most likely. I don't know if VCP can necessarily write a KESS MED9.1 flash read.
As a general rule it's best to use the same tool as was used to read, to do the write. Most ECU tools will correct the ECU checksum at the write step. So if you're checksum is written incorrectly the ECU could be bricked.
The posts looked like duplicates (x3)
I think removing the error code will definitely prevent the ACC from being switched off. However, in this situation the ACC still does not behave as smoothly as the old combination. Since you switched directly to 3AA ACC, the comparison is missing here.
drsedoy from the drive2 forum has had a similar experience and apparently made further adjustments to the ECU. The ACC brakes earlier and the "emergency situation" is practically avoided.
I have a friend who can lend me KESS for some time, so that I first program the DTC code and then deal with other ACC fields in the ECU.
Maybe drsedoy will answer my request and I will get some information. Maybe drsedoy will answer my request and I will get some information.
The way I understand it, (this is purely speculation), the problem arises when regular ACC braking tries to transition to front assist braking. There is an unexpected command received by (or sent by) the drivetrain controller (the ECU).
This causes the incompatibility fault and disengagement of ACC braking, which is obviously dangerous.
As it is now with the modified ECU software, in this instance the fault code is logged in the ECU, however it does not cause a disengagement, so braking continues. The fault is only noticed if doing a scan.
The fault code itself could be masked in the ECU so that it doesn't log at all.
There may well be a way to modify the MED9.1 so that it operates in the same way as the MED17 in B7 (or EDC for diesel) but the complete answer may be an ECU upgrade.
(Watch this space )
