Hi Kamold, your ACC retrofit guide has inspired me to do the same to my MY11 Passat B7 wagon. I'm so keen and can't wait as I have pretty much all the parts except for the radar sensor itself. Been struggling a bit to find a not-too-expensive B7 3AA radar but have found a couple of affordable B6 3C0 ones. Would the 3C0 be compatible with the B7? If not, can the 3C0 radar be flashed to work with the 3AA firmware?
Adaptive Cruise retrofit
Might be able to assist you there...2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Check your messages2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Wow thanks so much for this information!Originally posted by awef_spb View Postvag guru in russia flashed my ecu (2.0 tdi)
no error front assist now
need to change brakes line in dump file
Unfortunately, I contacted drsedoy about it back in January last year, but he has not responded since. I've tried again now. Now im looking for someone who can edit my dump with this information.
@kamold I tried to deactivate the error code myself, but I can't do it with the DTC Remover. I hope you still have time to have a look on it
Hi guys, having some spare time this past weekend, thought I'd kick-start the retrofit on my B7. I began with just plugging in the electrical side of the used ABS 3AA614109D which I got from Germany. Obviously had some warning lights come up at ignition on. Tried setting the coding similar to what I had on my original ABS. Wouldn't let me change anything at all, said something along the lines of invalid coding. Do you guys know if we need SA to be able to change ABS coding at all? Thanks!
Note: Can post autoscan later if required.
The coding string needs to be valid to be accepted.
Not enough info to go on.
Post autoscan with your original ABS connected.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
