Tigger73's 125TSI Tiguan Build Thread
  • Originally posted by 99Reza View Post
    Cheers for the info mate, appreciate that. I'm looking at 19 inch wheels with 9.5 width with blank offset, they can basically machine the wheels to have offset from et15 - 45. Probably best getting the arch extension first then play around with the offset later. Your stance will be the benchmark .
    No problem mate. Yes get the arch extensions first then decide how much offset you need to stay flush and not need any spacers. Also bear in mind that I have the Eibach Pro-Kit springs fitted too.
    Now back to topic please.
    2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
    • Back on topic now...
      Installed some S2T Flappy Paddle Shifters onto my steering wheel this morning (lowering springs are in too but I'll need to wash the car before taking any photos).
      Looks great but will need a little bit of getting used to as there is a little less clearance than with the standard shifters.
Name:	S2T Flappy Paddle 108.jpg
ID:	1807969 Click image for larger version
Name:	S2T Flappy Paddle 110.jpg
      - Tigger73's 125TSI Build
      • looks good! In your opinion how hard was the install of the s2t paddle shifters? i saw the DIY it didn't look too bad.
        • Originally posted by energie23 View Post
          Once you get your airbag out the rest is a piece of cake. Even though I've done the airbag removal before it still took me 15-20minutes of stuffing around with a screw driver and mirror to undo the retaining clips. The challenge is to stop the first clip re-engaging when going to attept the second... did this about 10 times
          • A few pictures taken this afternoon. Lowered springs in.... and yes Transporter I must spend more time and $ fixing up my house instead of on cars
            • Wheels, height, all looks good and balanced!
              MINI Cooper S Clubman - FWD
              • re: Tigger73's 125TSI Tiguan Build Thread
                Looking good.
                Sent from my GT-I9505
                Performance Tunes from $850
                Wrecking RS OCTAVIA 2 Link
                • Originally posted by nat225 View Post
                  Yes really happy with the springs. Before it was certainly sitting up but now it looks "planted".
                  Initial impressions is that I'm really impressed with the ride as the progressive springs do take out a lot of the smaller bumps that the stock ones transfer to the cabin.
                  Speed bumps are a bit firmer but that was to be expected. Will test out a few road humps and rougher roads in the next week.
                  • 'Planted' is a good choice of words. looks fantastic! If anything, the gap between the tyre & the plastic arch guard looks less than mine (i'm running a lower profile, i think? 245/40/19).
                    Not much left to do now, apart from the chrome plated grease nipples and double reverse overhead twin cam door handles! I guess there are a few more items on your wish-list...
                    Nice...
                    • Originally posted by MGV View Post
                      Nice...
                      Yes running 245/45/19 so I do have another 5mm to fill up the guards.
                      Hahaha I am almost finished - a couple of bits of hardware and software to go
                      • Wow Your Tig looks fantastic now. I am really exited about the looks. Any improvement in handling /cornering?
                        Lol .. I think now we will see the real stuff .. K04, BBK .. etc
                        2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
                        • Originally posted by Ramee View Post
                          It does corner slightly flatter - but remembering I already have front and rear sway bars in so they do a pretty good job at limiting the body roll. The main difference noticeable straight away (apart from the drop of course) is the variable rate springs ability to soak up the small bumps - it definitely runs over the manhole covers, etc with a lot less fuss.
                          You'll just have to wait and see
                          • Now that is one tough-looking Tig! Ride height is perfect.
                            Wonder how much further it'll drop once the springs settle. Hopefully not much... maybe 5mm?
                            • very nice!
                              • Looks very good.
                                I keep entertaining the idea of springs but it seems to handle our local happy laps reasonably well on OEM suspension.
                                Obviously if you are going to be pushing it hard the springs would be a worthy addition.
