Respect to those participating in this. Taking a risk in tweaking with your new baby, for the benefit of others. Good stuff.
Golf mk7: Auto Start/Stop disable switch - who wants to help?
The resistor is 100K and I was using it as a pull up resistor, I'll have a look on my protoboard design and cut it off it mightn't be needed.Originally posted by DV52 View PostAJW: just had another look at your (excellent) design. It looks like a dual mono-shot configuration with the first timer output being capacitor coupled to trigger the second mono (albeit I'm a bit confused about the need for the 10k pull-up resistor from pin 5).
I am impressed at the extent to which you have conditioned the trigger signal to ensure reliable start-up (both for pin 6 and for the reset pin 10) - and I thought that I was being ultra-conservative LOL! You have adopted a wise approach given the lack of information and the early days in our understanding of the car's electrical environment for the S/S kill switch. It might be possible to refine both our designs in subsequent versions.
The PCB screen and track layout clearly contemplate the solid state FET relay and the current limiting resistor, where as your wiring diagram suggests an electromechanical device. Will you be able to overlay the coil-relay over the PCB tracks on your PCB design, or will you put-in a second set of pads?
I was noticing that the second stage timer circuit (the one that drives the relay) could be triggered about 1 in 20 times when I applied a 12V Plug Pack directly to power the PCB.
If I used a switch inline with the power and turned it off/on it always worked.
The overboard design was also to help with this random triggering event and not knowing exactly how the power would come on when the car starts. In a lot of older cars starting the car also dips the supply rail enough that things will reset.
Yes there's a difference in my circuit diagram and PCB layout.
I started with a relay then decided I wanted to use SMD so went looking for a Solid State relay.
On my Protoboard I'm using a Photomos relay that's using a LED (IR?) to make a Mosfet conduct.
They're only good for low current and lower voltages but it should work in this application.
So on the PCB layout I'm using a G3VM-61G1 - normally open solid state relay.
I'm hoping to have my car this Friday so I can check some things out with my design.
Thanks Mattaus for showing how to pull apart the switch cluster, doesn't look too bad.MY21 Golf MK8 GTI | Kings Red Metallic | all options |
MY16 Golf MK7 GTI PP | White | With Leather |
MY11 Golf MK6 GTI DSG | CW | 5dr | Bi-Xenons | ACC | 18" Detroits | RNS510 with Dynaudio| RVC | MDI |
AJW: Not sure what type of 12V Plug pack that you used, but I've found in the past that the performance of these packs are highly susceptible to the load on switch-on. I suspect that it has to do with the quality of the internal switched mode design, but I've found that some have a notorious high ripple that is injected onto the voltage bus if they are loaded on switch-on. I wouldn't be worried about this aspect of your design.Originally posted by AJW View PostI was noticing that the second stage timer circuit (the one that drives the relay) could be triggered about 1 in 20 times when I applied a 12V Plug Pack directly to power the PCB.
If I used a switch inline with the power and turned it off/on it always worked..
I considered filtering the power supply pin on my ciruit, but the problem is that for the device to work properly, both our switches need the voltage at the Vcc pin to accurately follow the Terminal 15 rail. If we beef-up or filter the power supply ciruit too much, we run the risk of missing multiple quick starts of the ignition(I think)
DonPlease don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
Just looked I'd removed the 100K pull up resistor on my Protoboard design anyway.
I guess that's one less component, I'll need to change my PCB layout now.
I think I also saw the second stage random trigger issue on a regulated bench supply.
At least with the design I've got now it seems fairly robust.
I was also looking at supply filtering but realised like you that it stuffs up the power on triggering.
I have got a 100nF cap as on the supply rails for the NE556 - this will also reduce voltage spikes when the output transistors of the timer change states.
There's some good 555 info at this website that has some good reference material.
555 Timer CircuitsMY21 Golf MK8 GTI | Kings Red Metallic | all options |
AJW: Great news about the 100K resistor -my philosophy these days when designing circuits is that every component on a PCB needs to earn its place there - there is no room for lazy/idle components !!Originally posted by AJW View PostJust looked I'd removed the 100K pull up resistor on my Protoboard design anyway.
555 Timer Circuits
Your design inspired me to add a couple of free wheeling diodes; to supress the possibility of negative spikes from the relay coil (getting into the monostable oscillator) and to filter out noise on the 12V rail. I'll update the circuit diagram on my first post later, but I've included the extra components in the physical layout for Mattaus's benefit when he puts the components together. You might want to think about doing something similar to your design.
Yes, filtering the power supply will come at the cost of making the S/S kill device more sluggish. Not sure if a 100nF capacitor will do much to stabilise the supply rail on your board, but I don't think that it will do any harm if you leave it in-circuit. There may need to be some tweaking to my design in respect of power supply conditioning, but I'll wait for feedback from Mattaus.
With my circuit and looking at your circuit too, I've no doubt that they will operate as intended, The real measure of success though will be the long-term stability of the devices with events like the air conditioner switching on/off (causing the 12V rail to fluctuate) and human practices like switching the ignition on/off quickly. I guess a few hiccups can be tolerated, but systemic misfiring is the real issue with both our designs (IMO). But let's wait until the devices are actually installed and trialled
Thanks for the 555 link - good resource!
DonLast edited by DV52; 12-10-2015, 03:07 PM.Please don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
OK, so taking the centre console apart a second time was a piece of cake. Literally took me about 30 seconds. I checked; nothing is broken lol.
I fashioned up some super professional needle probes:
First problem I discovered is that the wires VW use are NOT easily pierced. Like, it's impossible without tearing them apart or stabbing yourself in the finger. Thankfully I managed to get a bit more slack out of the wiring loom and just shoved the needles into the back of the plug itself. It's actually a better way to do it because there is zero damage being done
Here's a video of my efforts:
Yes, I had the leads connected backwards. Stupid, but the DMM was actually upside down when I hooked them up and I wasn't thinking straight. Also, I kept calling the bloody button "traction control". You know it isn't, I know it isn't. Let's just put it down to a Monday spent in 6 hours worth of meetings that some bright spark (not me!) decided should start at 8:30am. Oh, and when I was uming and ahing about what to call the blue and black wire, it was because I thought there was a more technical name for it. I guess the best I can come up with is S/S switch wire
Anyway, as you can see the voltage I was getting across the switch itself was only 2V. Dropped to zero as expected. The voltage from T15 to GND is 12V when ancillary power is on, and 14.1V when the engine is running. Also as expected. There was a delay in the T15 voltage jumping from 12V to 14V though; probably around 5 seconds. It doesn't budge when you press the S/S button. No video of that sorry.
So all-in-all, nothing we didn't expect?Last edited by mattaus; 12-10-2015, 05:46 PM.2016 GTI Performance | Pure White | JB1 | Dog Bone | Full Tint | Stop/Start Delete | Avatar by sandwg
Matt: Well done- I like no surprises!! Also thanks for the video!Originally posted by mattaus View PostOK, so taking the centre console apart a second time was a piece of cake. Literally took me about 30 seconds. I checked; nothing is broken lol.
The 2 volt DC reading is interesting and somewhat surprising. I assumed that this would be a DC voltage, but perhaps it's actually an AC trace - can't imagine why though given that it's simply shorted out by the S/S switch. Could be that PIN#60 on the BCM needs to see an actual signal form of some sort (rather than a DC voltage) when the native VW S/S switch is not closed (only guessing). I'm glad that my design uses a relay contact rather than a solid state switch - because the electrical isolation that results from the raw contacts doesn't impact in any way on the conditions of the signal on PIN#60.(hint to AJW - don't use the FET relay)
Don
PS: Try not to pierce the wires too often, If you can, leave the needles intact - less damage to the copper core this wayLast edited by DV52; 12-10-2015, 08:10 PM.Please don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
I assembled the circuit and after a quick phone call to Don in order to verify that I am in fact an idiot, the device was verified as working and ready for a test run in the car:
VW Automatic Stop/Start Deactivation Device Test
My observations:
- I didn't fiddle with the timings at all. For what it's worth I actually like how quickly it activated.
- Any delay you build into these devices that starts from the moment the circuit senses power, will literally start the nanosecond you press start/turn the key. So you definitely want enough delay to ensure the S/S system is deactivated AFTER the engine is at idle. Not sure what the consequences of it deactivating too early would be, and I don't want to find out.
- There was some concern that the jump from the ancillary 12V to cranking 14V would cause the device to 'reset'. This didn't happen.
- The 2 second activation time is completely unnoticeable (by virtue of how the switch actually functions). It could be cut down a lot, but it doesn't hurt either way. Probably safer to leave it as is.
- Plenty of room to install the device in and around the gear shifter. Your mileage may vary with a manual shifter though.
- We need to work out a robust and easy way to actually interface with the existing wiring loom. I'm going to do some research and see if there is an adapter we can buy that would suit.
- More in-depth testing is definitely needed, but this cannot be done until I have a way to interface with the car better (see the point above).
All in all, a pretty damn good result for a first try. Testament to Don's brilliance if anything
- MattLast edited by mattaus; 12-10-2015, 07:39 PM.2016 GTI Performance | Pure White | JB1 | Dog Bone | Full Tint | Stop/Start Delete | Avatar by sandwg
^^^^ Matt: I don't want this to sound like a mutual admiration thing, but my very deepest appreciation for your efforts. I'm making no comment about the way that the components were soldered together (in the video), but the ultimate test is -does the damn thing work -and apparently it does. Wooo-weee halleluiah big G!
So, it seems that the preliminary results are encouraging. But before we both get too excited, I think that we need to understand if there are any longer term issues to address. (i.e. with the car operating under lots of normal conditions).
As discussed, I reckon that you should settle on initial values for T1 and T2. Then dab a dob of glue onto the two potentiometers (something not too strong). Then package-up the components into a sleeve of heat shrink tubing and semi-attach the device to the three wires (so that it can be removed if further modes are needed). Then just drive the car as normal and observe any idiosyncrasies that may arise (with the device- that is).
I'm anticipating receipt of the second monostable oscillator by post later in the week. I'll solder together my unit and post a pic of the arrangement.
Again many thanks for your sterling efforts and for your input to the early stages of this fledgling device!
Don
PS: There's a simple solution if the voltage rise from 12V to 14V (because of the alternator kicking-in) becomes problematic. We could just run the device at a lower voltage (5 Volts, say) by placing a 3 pin regulator in front of the mono. The regulator would provide electrical separation for the mono from the voltage rise (all that would happen is that the volt-drop across the 3 pin regulator would increase when the alternator started - end effect would be an increased power loss in the voltage regulator. But since the device doesn't use much power, the increased heating would be marginal) I would need to change the specs of the relay if this was necessary, but this is not a problem (the TRR1A12D comes in a 5 volt version).Last edited by DV52; 12-10-2015, 08:49 PM.Please don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
I'll settle on some values pretty easily. I won't attempt to put it back in the car until I have a better way to install it and it may take some time to fine something that will aid with that. I'll also very probably take it all apart and re-assemble it. My eagerness probably got the better of me tonight. That said I'm only going to reassemble it so that it's better suited for wrapping. Might be a few days or even a week or two before it's ready to be installed back in the car.Originally posted by DV52 View PostAs discussed, I reckon that you should settle on some values for T1 and T2, then dab a dob of glue onto the two potentiometers. Then package-up the components into a sleeve of heat shrink tubing and semi-attach the device to the three wires (so that it can be removed if further modes are needed). Then just drive the car as normal and observe any idiosyncrasies that may arise (with the device- that is).
EDIT: Found this picture whilst searching:
If the author's description is correct (and from the picture I have no reason to believe my connector is any different) I should be able to remove the 3 pins from the connector, wire directly into the pins themselves, and re-insert them. Not something an electronics noob should attempt so a DIY friendly method would still need to be devised. For extended testing purposes however, it should work a treat. I just need to purchase some much thinner gauge wire because the stuff I have is made for high current applications and will not fit inside the connector what-so-ever.Last edited by mattaus; 12-10-2015, 10:10 PM.2016 GTI Performance | Pure White | JB1 | Dog Bone | Full Tint | Stop/Start Delete | Avatar by sandwg
Great job Mattaus + Don, at least we know it will work now - just looks like we need some more testing under various conditions.
One thing that might be worth testing is using your mobile phone near the circuit, would be interesting if you could trigger it if you make a phone call. (That has me thinking I might shield mine).
Just noticed Mattaus that you've got the same car as me MY16 GTI PP White, although I'm still waiting for mine so it should be exactly the same and I can compare the results you're getting.
Interesting about the 2 V, wondering if your meter was picking up stray voltage around the switch terminals.
In my experience any electronics that has mechanical switches attached will have some reasonable debouncing / Conditioning circuitry on the front end. Ideally it will be setup so that it doesn't need to see a dead short to ground to activate and can expect to see some noise on the line and not trigger, especially in a harsh electronic environment like a car.
The solid state relay that I'm using has a 1ohm on state and a 1000Mohm off state so I'll be surprised if the circuit is that fussy with the device. If it doesn't work I'll go back to a relay, I was using one before.
Looking at the connector picture I was going to try removing the pins if possible and solder wires directly onto contacts. I don't like having connectors between to many points, they cause issues latter on.MY21 Golf MK8 GTI | Kings Red Metallic | all options |
FMatt: If my guess is correct, this picture comes from a fellow forum colleague called SHFT (EDIT: picture was clearly posted by Golfdave -link here). Anyhow, unfortunately for some, the pic tells more of a story than your clever suggestion about removing the pins.Originally posted by mattaus View Post
If you look carefully at the picture, you will see that there are no wires for PIN# 9 and PIN# 10 on the connector(bummer!!). Notwithstanding that the picture was taken from a UK vehicle, this means that for those mk7 models that don't have a TCS/ESP button (like mine), the option of using PIN# 10 for T15 supply to the mono doesn't exist (Bummer, again!!). So for this variant mk7, the switched 12Volt supply would need to be spliced into the ciggy socket.
The next time that you pull the centre console switch apart, can you see if there is another Black/Yellow wire (other than on PIN #10) in the vicinity - please. In particular, I'm hoping that the wire to the ciggy socket is routed somewhere in the area of the panels that need to be removed near the centre console switches- fingers crossed!
Don
EDIT: attribution for picture correctedLast edited by DV52; 13-10-2015, 10:50 PM.Please don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
I will test this when I hook everything back up and report back. Not sure when that will be as I'm considering making a PCB to put the relay on because my manual soldering skills suck and there is a two to three week turnaround from OSHParkOriginally posted by AJW View PostGreat job Mattaus + Don, at least we know it will work now - just looks like we need some more testing under various conditions.
I don't have leather, but the mixed interior on the PP is quite niceOriginally posted by AJW View PostJust noticed Mattaus that you've got the same car as me MY16 GTI PP White, although I'm still waiting for mine so it should be exactly the same and I can compare the results you're getting.
I'd be worried if we get different results lol! Then again my DMM isn't exactly Fluke quality...
Not sure I follow what you want to do exactly? YOu mean remove the pins and replace them with your own, or juts wire into the existing pins like I intend on doing? When I'm done, all you'll see are two wires going into three of the pin gaps in the back of the plug. That's the plan anyway!Originally posted by AJW View PostLooking at the connector picture I was going to try removing the pins if possible and solder wires directly onto contacts. I don't like having connectors between to many points, they cause issues latter on.
Don, that sucks! How are the other buttons in the cluster functioning then, or are there none in your model? From memory there are no wires on that side of the shifter, and the ciggie lighter is not easily accessible from the shifter cavity without pulling more panels. That being said, there is a wiring loom on the other side of the shifter for whatever buttons are on that side (only a parking sensor button on my car) so maybe that can be hooked into? I'll definitely take some pictures for you and see what I can find thoughOriginally posted by DV52 View PostMatt: If my guess is correct, this picture comes from a fellow forum colleague called SHFT. I did some early work with his/her? thread in fitting an ESP button on his car (I'd forgotten). Anyhow, unfortunately for some, the pic tells more of a story than your clever suggestion about removing the pins.
Matt: I have an MY13 model which simply has the native VW S/S disable switch on the LHS bank and the park pilot switch on the RHS bank. Neither of these buttons have a T15 wire as they both short-to-earth a signal from their respective control modules (the BCM in the case of the S/S switch and the parking aid control unit in the case of park pilot switch)Originally posted by mattaus View Post
